Previous in Forum: Mixing Flights for Lexan Liners   Next in Forum: High Pressure to Low Pressure Steam Ejector Conversion
Cutting Tools for Spring Steel
10/08/2008 12:59 PM
what tool should be used to cut spring steel wire on high speed automatic spring machine, dont suggest for carbide tip or white hss bits...
shamsher singh (mech engineer manufacturers)
Pathfinder Tags: mechanical engineering Tools
Good Answers: 25
Re: Cutting Tools for Spring Steel
10/12/2008 12:20 PM
I would suggest that you design in a momentary stop, "for a wet cut, meaning submerged" and the use of a circular saw with a diamond edged blade of a fairly large diameter. This type of steel is quite hard, has been tempered and you want to make your cut quickly and with out heating the area that is receiving the friction created by the cutting activity. When drilling spring steel, I have read that it is best accomplished submerged in a cooling solution. Therefore: it makes sense to keep the cut as cool as possible.
TMF
The only problem with common sense, is that not very many people have it, or know how or when to use it.
