Previous in Forum: Grounding Transformers in Control Circuits   Next in Forum: Generator Stator Earth-Fault Protection at Low Frequency Injection
Mathematical Equation for Power Factor of 1 in Single-Phase Motor
10/08/2008 1:42 PM
Goal:
How do I calculate the inductance (Xi) in a single-phase motor so I can add the appropriate capacitance (Xc) to null the reactance (Z) in my circuit to and get true resistance (R)?
Strategy:
120Vac 60Hz Supply. 1/70hp 0.6amp motor nameplate. Using a meter that measures inductance; I measured the motor stator as (35mH) resistance (13ohm). Using induction and phasor (polar) equations, I came up with 1uF to cancel the reactance in the circuit.
Implement:
Bench test supply current 0.6A, load current 0.6A without capacitance (1uF).
Bench test supply current 0.6A, load current 0.6A with capacitance (1uF).
Evaluate:
But, when I replaced the (1uF) capacitor with (10uF);
Bench test supply current 0.3A, load current 0.6A.
Excellent improvement. Supply current halved.
Sleepless in Illinois:
Can anyone inlighten me on an equation?
Good Answers: 101
Re: Mathematical Equation for Power Factor of 1 in Single-Phase Motor
10/08/2008 4:34 PM
http://www.allaboutcircuits.com/vol_2/chpt_11/3.html has your answer, and can give it in a better format than i can on this thread.
10/08/2008 5:14 PM
The answer is 102uF.
Good Answers: 101
10/08/2008 5:28 PM
Funny, I get exactly double that @ 204uF. Could you show the equation you used, i would like to see where i went wrong.
10/08/2008 5:43 PM
I just calculated the impedance of a capacitor in parallel with a resistor and inductor:
Zc // (Zl+Zr)
And then calculated what the capacitor should be to get an impedance that is strictly resistive. It was basically:
1/(jwL + R) + jwC
It's messy so I'm not ruling out that I may have made a mistake instead of you.
Location: Next to the Prime Merridian (51°29'34.50"N 0°13'32.85"W)
10/09/2008 4:41 AM
Same here, I must have got something wrong.
Making mistake is part of learning.
10/09/2008 5:48 AM
True power 1/70hp Ptrue = 10.657w Voltage V = 120V Inductive Current IL = 0.6A Apparent power Papp = 72 VA  Papp = V*IL Power Factor cos ø = 0.148  cos ø = Ptrue / Papp Reactive power Preact = 71.2var  Papp^2= Preact^2+Ptrue^2 Capacitive Reactance XC = 202.23 Ω XC = V^2 / Preact Capacitance C = 13.124μF C = 1/2*pi*f*XC Capacitive Current IC = 0.6A  Ic = V/ Xc Supply Current Is = 0.3A  1/Is = 1/IL+1/IC
10/09/2008 5:50 AM
bear with me, i dont know why it is appearing like this...
Register to Reply 7 comments
Anonymous Poster (2); Isti80 (1); kayems (2); RVZ717 (2)
