Previous in Forum: Name This Tube!   Next in Forum: Cost of IGBT
Locked Rotor Current
10/10/2008 1:14 AM
Hello,
Can anyone help me to find out the rated current/locked rotor current & load factor of a 15KW motor which is connected to 415V ac.Estimated full load current & maximum demand are 26Amps.Load diversification=.06.Thanks in advance.
Re: to find locked rotor current
10/10/2008 5:11 AM
Apply a multimeter between phase connections of a single winding, set to ohms, or possibly milliohms. Divide the resistance figure into the supply voltage. Bingo.
10/10/2008 7:22 AM
A rule-of thumb: the locked-rotor current is 5 times the full-load current for direct-on-line starting.
10/10/2008 7:27 AM
Thank you.It was helpful.
Re: Locked Rotor Current
10/11/2008 7:22 AM
The NEMA Standard MG- 1 has recommended the maximum locked rotor current of single-speed three phase motors for the various rotor designs B, C, and D, for various recommended torque values. These have been derived for a 415 V a.c. system and are shown as following:
20 hp (15KW) ------------ 178A (locked rotor current)
Also typical rated power factor for this rating is 0.86, as you know power factor in motor starting duty is very low.
Creative thinking is enjoyable, Then think about your surrounding things and other thought products.
10/11/2008 1:38 PM
LRC is normally 6 times rated current+-20%.Usually it is +tolerance.If full load current is 26A then LRC is between 156 Amps-187.2 amps.It is independent of other parameters but depends upon the motor design .Duration depends upon the load inertia.
Anonymous Poster (1); nesubra (1); PWSlack (2); veronica (1)
