Previous in Forum: GEC Alsthom AVR   Next in Forum: Hi!
Actuators in Sequence
10/10/2008 7:57 AM
Hi Everyone,
I am not electrically inclined, one might say I have an electrocuted thumb rather than a green thumb, so please excuse my lack of terminology and also keep this in mind in your answer.
Situation: 3 12VDC linear actuators connected to one toggle switch.
Desired Action: Push the switch in the open position and actuator 1 is activated. Two seconds later actuator #2 kicks in as well. Five Seconds later actuator #3 kicks in. All actuators continue to extend to their full extention (no problem there, they freewheel). I don't want intermittent operation of the switch to confuse this action.
Push the switch to close actuator #2 is activated for 2 seconds, after which actuators #1&#3 are activated and all actuators continue to their full retraction. Again, intermittent toggling of the switch should not confuse the motion.
Any creative ideas are welcomed.
Re: Actuators in Sequence
10/10/2008 8:21 AM
The possibilities begin with a motorised rotary sequencer, a bit like the one to be found in older washing machines and available from any number of on-line outlets for a few £GBP, to individual relays and timers, which will be a bit more, to a small programmable logic controller.
So it depends upon the project budget, more than anything.
10/10/2008 8:43 AM
Hi PW,
thanks for the input. I am currently working with a single shot relay timer. One major issue is that Actuator #1 sees current for a split second, which puts things out of kilter. I have a programmable logic controller, and a motor controller. Budget is not so much a factor (within a few $100). My biggest problem seems to be my electrical illiteracy, which prevents me from accurrately communicating, hahah.
Thanks again.
10/10/2008 10:47 AM
If you've got a PLC and you (or someone you can call on) can program it, it should be straightforward. You'll need (minimum) one free input and 3 free outputs.
What make/model is the PLC? How much spare I/O is there?
10/10/2008 10:52 AM
Sorry? PLC? I/O? ROFL, remember I am electrically illiterate! I know how to hook up wires to my 12v drill battery and make things move. I can do a very basic program on the controller, it has a sort of ladder logic thing. It is a Crouzet Millenium 3.
Thanks
10/10/2008 11:03 AM
I've got the Millennium 3 software - I'll try to find time over the weekend to knock up a simulation. Which model is it?
10/10/2008 11:34 AM
Hi John,
I've got a CD12, and have been trying to write a basic program on it. Needless to say, being illiterate of the correct symbols or terminology has resulted in some amusing results. Your help will be vastly appreciated.
Paul
Register to Reply 6 comments
JohnDG (2); pashbe1 (3); PWSlack (1)
