Previous in Forum: Sulphur prilling unit belt stress corrosion cracking   Next in Forum: column height
Flange due Hydrotest pressure
10/12/2008 11:41 PM
Dear All Members,
I have one stainless steel vessel with 14.5 bar internal design pressure, 50 degree Celcius, use SA 182 Gr. F316L 150# Rating(Material Group 2.3) According to code UG-99b[34], hydrotest pressure =1.3 x design pressure =18.85bar but as per table 2-2.3 ASME B16.5-2003, the max pressure of these flange is 15.3bar. That will effect on Flange rating or not?
Could anyone clarify to me?
thank you
Engineering Fields - Mechanical Engineering - New Member Technical Fields - Technical Writing - New Member
Good Answers: 21
Re: Flange due Hydrotest pressure
10/13/2008 5:00 AM
Look over to the next challenge
