Previous in Forum: Flange due Hydrotest pressure   Next in Forum: Water in Fuel Lines in Rotary Screw Air Compressors
column height
10/12/2008 11:56 PM
Dear Sir,
I am working in power plant
in my plant boiler structural column height is 45.5 meter and 4 joint
in that how i can check the verticality and alignment
pls help thi reg
by madhavan
Engineering Fields - Mechanical Engineering - New Member Technical Fields - Technical Writing - New Member
Good Answers: 21
Re: column height
10/13/2008 7:41 AM
Look over to the next challenge
Re: column height
10/13/2008 1:17 PM
This may be helpful 1. First lift columns verticality may be checked by piano wire with conventional plumbs form top keeping away form the column for a standard distance 2. The alignment shall be completed with beams and bracings for the first lift. 3. Second lift and first lift combine with piano wire and conventional plumb 4. The same way remaining lifts shall be completed. Or You can use some verticality measurement instruments
Register to Reply 2 comments
