Previous in Forum: Powering up a Foundation Fieldbus Transmitter   Next in Forum: Cable Voltage Rating
15 comments
Electronic switch
10/13/2008 1:47 AM
May i know, Is there any electronic components which is of low cost and compact in size that can be used in place of electro mechanical relays.ie it should make a contact chengeover if it gets +5VDC.
Re: Electronic switch
10/13/2008 3:20 AM
It depends what voltage and current it will be switching.
If it is switching DC ( at say an amp) then an FET or transistor will do the job.
If switching AC (low/medium current) then a Triac (suitably chosen with logic level switching).
10/13/2008 3:31 AM
Thanks...but my exact requirement is to change the contacts from NC to NO(make to break) when it gets the 5 VDC volltage.I think transsitor and FET starts conducting (ie from NO to NC)when we provide the bias voltages.Even if i have some pulse type changeover also..it is OK.
I can use a relay, but it occupies more sapce and costs more.
I'm going to use to cut off the existing relay when this circuit gets voltage of 5 V.
10/13/2008 3:43 AM
Just use a second transistor or FET to invert the 5v signal!
Or use a Transistor/FET of the opposite typ e.g PNP transistor or P type FET.
(This assumes you have some voltage avilable for bias)
10/13/2008 4:32 AM
I'm more of instrumentation..not having deeper knowlwedge in electronics...could you pls explain me in detail possibly with a circuit diagram for changing a contact from make to break after getting DC voltage.
10/13/2008 5:35 AM
I think it should work if i put the invertor ouptut acorss the relay coils...let me try and confirm
Hobbies - CNC - New Member Hobbies - Musician - New Member
10/14/2008 4:45 AM
P channel logic level FET. Chose a suitable one to carry the required voltage and current over here: irf or infineon or other MOSFETs manufactures. If you have very fast switching speeds you may need a FET driver (push pull) to take care of gate charge capacitance.
hope this helps
Think and move like an electron
Good Answers: 12
10/13/2008 11:28 PM
Try googling this;
AS5W-K 5V from TAKAMISAWA
We use these on most of our products
10/13/2008 11:40 PM
Dear sir,
good day !
our company can supply many kinds of relays and switch, you can visit our website http://www.anovay.com for detail .
any needs or questions ,please feel free to contact me .
best regards
jessie
jessie@anovay.com
10/14/2008 6:53 AM
There are a lot of "solid state relays"small dip ,different trademarks..Gordos Corp.,I.R.,Potter and Brumfield...Go to a good industrial electronics devices distributor.-
10/14/2008 9:41 AM
Do you need optical isolation?
try http://www.opto22.com/
They have AC and DC Outputs and Inputs.
Bill H.
10/14/2008 9:53 AM
I am a bit confused with your question...Is this a simple change over, latching or flip-flop?... Why don't you add a circuit so we can help...
Do you want the contact to stay close (or open) only as long as the +5V is present? or do you want the relay to latch?, meaning the +5V is only a short duration pulse just long enough to energize the relay. Second question is what are you switching? rate the Current and voltage.
Wangito
Never trade luck for skill.
10/14/2008 11:51 PM
hi,
Actualy I'm switching a load rated 4A through a relay...I'm laready latching this relay through his own contact.Once the realy has got latched ,load gets power continously.In order to switch off the load i need to delatch this contact . whts my earlier plan was to put a NC contact of another relay inseries with the former one.This will work for sure..But it occupies more space n cost..thats y I'm looking for an electronic component which can deenergise this after getting a pulse/ continous command.
10/15/2008 6:55 AM
How do you release the the relay now? manually or electrically.
As I said, it would be nice to have the present circuit.
Wangito.
10/15/2008 6:59 AM
I'm going to use a inverter circuit across the relay...So that when I get 5 VDC it will momentarily deenergise the relay opening the latched contact...But this is not yet checked..hope it will work...
10/14/2008 10:41 AM
What about a 14053 triple multiplexer de-multiplexer: works just like a changeover relay:-
http://docs-europe.electrocomponents.com/webdocs/05fb/0900766b805fb5ba.pdf
You probably need to check the ON Resistance (quite high for the CD/MC14053 lower for the HC14053).
For more information on analogue switches see this:-
http://www.maxim-ic.com/appnotes.cfm/an_pk/638
If you need a metallic contact then driving the relay coil the other way round may work:-
Can't post pictures at the moment so here's an attempt at a text picture:-
...In>-----╔═════╗............+5V-----╔═════╗
....0V-----╚═════╝............In>-----╚═════╝
Aaaaagh! don't know where that ═ keeps coming from, but I think you get the idea.
Register to Reply 15 comments
Anonymous Poster (1); Bill H. (1); daffy (1); ferquiza (1); karthickranii (5); madness (1); Randall (1); user-deleted-1105 (2); wangito (2)
