Previous in Forum: Grounding screw assembly rules, succession of parts   Next in Forum: Automations (remote -home automation)
Looking for an IC Number
10/08/2006 2:27 AM
sir,
Does anyone know the part # of an 8 pin IC having 1stVcc (+ve5v), 8th Ground, 6th & 7th out puts -each 4.8v for a minute by triggering 4th pin? This IC is used to close the relays to run the 2 no of dental chair motors.
Re: Looking for an IC Number
10/09/2006 12:23 AM
No numbers on the IC? Almost every IC has a part number etched in top of it. Sometimes they can be hard to see. I usually swipe a little white heatsink grease on top to make the number more visible but make sure to rid yourself of static.
No luck with the manufacturer?
Brian
10/09/2006 12:42 AM
Sure sounds like a 555 or similar timer chip, with the pin numbers backwards. With the dot or notch on your left, top view, Pin 1 is lower left and pin 8 is upper left. If you are looking at the bottom, the dot or notch is on your right when pin 1 is bottom right & pin 8 is top right.
You might be interested in: PIN Diodes, IC Modems, IC Timers
