Previous in Forum: 5v Voltage Regulators   Next in Forum: electrical engineering
8 comments
60HZ v/s 50HZ
10/13/2008 10:12 PM
how to use 60 HZ power supply unit on 50HZ supply. Fequency converter for 40KW seems very prohibitive.
Rather, What will go wron if we connect 60HZ power unit to 50HZ supply?
the unit is rated 40KW/500A/80V/OCV 150 used for plasma spray
Re: 60HZ v/s 50HZ
10/13/2008 11:12 PM
What happens if you connect a 60 Hertz motor to a 50 Hertz mains:
The motor turns 17% slower
The internal current goes up by 17%
The power (watt) goes down with 17 %
The mechanical cooling is less, because of 17% less turns
The result is a higher current, then designed by the manufacturer and the insulation of the electrical wiring deteriorate much quicker, which after sometime results in a burn-out.
Re: 60HZ v/s 50HZ
10/14/2008 12:52 AM
Thank you.
In that case can I run the equipment at leasser current ( 410 A 17% lesser han rated 500A) and give additinal cooling to the SCR and transformer by keeping power unit in Aircon room. Pl note there is no rotating part in this power transformer except cooling fan.
Re: 60HZ v/s 50HZ
10/15/2008 12:09 AM
please furnish calculation for the same.
Re: 60HZ v/s 50HZ
10/14/2008 5:56 AM
if u connect a 60hz power unit to 50hz supply it produce serious damage to the machine or equipment. take a bulb in a second it turns on and off for 50 times. that u cant observe with ur naked eye. in 50hz system number of cycles in a second are 50. so the device responds 50 times in second. if the equipment is designed for 50hz it must be operated in this constraint. a 60hz system is powerful compared to 50hz. in swedan they use this sysem to drive trains up the hill
Re: 60HZ v/s 50HZ
10/14/2008 2:50 PM
A light bulb would turn on and off 120 times per second at 60 Hz and 100 times per second at 50 Hz.
Re: 60HZ v/s 50HZ
10/15/2008 2:10 AM
"in swedan they use this sysem to drive trains up the hill"
Oooooh .... I see ... That's why our trains in most parts of Europe (50Hz) go uphill so slow...
44mEurope
Re: 60HZ v/s 50HZ
10/15/2008 3:42 AM
In Switzerland 162/3Hz is used to drive trains up hills. Grüzi!
Good Answers: 73
Re: 60HZ v/s 50HZ
10/14/2008 8:46 AM
Check with the equipment manufacturer. It is likely that the incoming power is first converted to DC in which case the concern may be very small. It all depends on how "international" the circuit designer was when he created the equipment.
Register to Reply 8 comments
44mEurope (1); Anonymous Poster (4); NotUrOrdinaryJoe (1); PWSlack (1); wareagle (1)
