Previous in Forum: Cold Welding of Copper Wire   Next in Forum: Electrical Heated Mixing Equipment
Ovens
10/08/2006 10:11 AM
I want to make an oven for doing powder coating. Any suggestion on materials?
Good Answers: 18
Re: Ovens
10/08/2006 1:53 PM
You didnt state wheather this was for home or commercial application but heres a very simple and economic way of doing this. Ride around on trash picup day and look for the biggest oven you can find. Usally if they dont work its easy to fix. All that you are looking for is that both oven elements work and the thermostate works. If after checking you dont like the one you have just sit it out for trash pickup and go find you anouther one. I would look for a stand alonen or wall mount unit myself. Remove the racks and install some eye hooks in the top and make some stands for the bottom so you can place your items in the oven suspended. Now dont plan on using the one in your kitchen because you have to stay on good turms with the better half and besides you may not want to eat out of your powder-coat oven. Keep in mind the temper in some metals can be affected at this low temperture.
jeconway
For every great advancement in medicine there is an equal and opposite advancement in the denial of treatment.
Re: Ovens
10/08/2006 7:27 PM
thanks for that suggestion jeconway. I'M going oven hunting. Thanks!
Re: Ovens
10/09/2006 9:42 AM
www.jamestownpowder.com is a good source for your powder coating questions. Our shop made oven is a simple fire brick affair. Fire brick can be purchased most anywhere brick is sold. For heat we chose propane to fire a burner scavenged from a dead water heater. The use of any oven thermometer will do to monitor interior temperature.
Hope this helps. Del Sol Engineering.
Re: Ovens
10/10/2006 6:29 AM
I shall be happy to design the powder coating oven for you. Pl. send me the following details:
1. continuous or batch
2. dimensions, weight & sketch of jobs
3. production/day
4. no. of working hrs./day
5. loading: whether resting on trays/trolleys or hooked to the top
6. heating: elctricity or gas (natural gas or LPG - if natural gas, density of gas) note: only electricty & gas can be used for direct heating ; for any other fuel, indirect heating is to be employed, which will only reduce efficiency and increas fuel costs..
7. rates of fuel: electricity (inclusive of MD charges) & gas
tks. & regs.
mn mahadevan
E-mail: n_mahadevan2002@yahoo.com
Register to Reply 4 comments
DEL SOL (1); Jerrell Conway (1); Metalman (1); mn mahadevan (1)
You might be interested in: Laboratory Ovens, Vacuum Ovens, Industrial Ovens
