Previous in Forum: Operating manual of Atlas Copco screw compressor   Next in Forum: Piping Pressure Calculation
8 comments
insulation efficiency
10/19/2008 4:17 AM
suppose there is a line to which steam is entered in temperature T and pressure P. the lenght of line is L and there are some branches connected to the header. is there any software or method to check the efficiency of insulation in this line. in better expression I want to enter the inlet and outlet temp. and select an insulation type and thickness and ask for efficiency and heat loss.
thanks
Re: insulation efficiency
10/19/2008 4:56 AM
There sure is - here's a free one that should help you out:
http://www.pipeinsulation.org/
Good Answers: 19
10/19/2008 3:46 PM
Thanks Guest. Please register and identify yourself so that I know who i am thanking for this important software which, today i have because of you . Now I can do away with my guess work & practical experience.
10/19/2008 5:29 PM
Thanks, but I must politely decline registering, I am not sure if you have followed previous threads with my "mystery" answers - but I prefer to remain anonymous.
But, I will leave you my signature smiley
Good Answers: 19
10/20/2008 12:06 AM
Smiley - You are getting interesting and I like your style to remain anonymous. Your mystery answer threads did pass by but I did not take notice. Now I have a fair feeling of your writing & intellectual style and will recgonise you even if you do not sign as smiley.
10/20/2008 1:01 AM
Yup - you are onto me, darn ..................... I am going to have to make a conscious effort to change my writing style.
Good Answers: 19
10/19/2008 3:39 PM
Take an infra red temperature & measure temperature. anywhere between 38c to 42c is a 95% good insulation. Better - just put your palm and if you can stand comfortably, that's a 90% good insulation.
Personal experience: Steam mains upto 15 bar 1/2" to 3" -2" insulation thickness, 32 kg/m3 density & 4" to 12" mains - 4" insulation thickness, 64 kg/m3 density if fibre glass wool blanket 240c.
Now since mostly rockwool with minimum 80 kg/m3 - 2" thickness till 3" main & 4" on 4" main & +.
Thermo oil lines 250c - minimum 100 kg/m3 density 550c.
Above only based on my practical experience. Serves my purpose.
Checkup spec sheets of insulation material & type preferable to you, apply as per desired thickness, density & temperature.Also depends what is locally available.
10/19/2008 5:41 PM
Another program I just found is located at:
http://www.cheresources.com/inssoftwarezz.shtml
NOTE: I have not downloaded nor tried this program so I can't really vouch for it.
Good Answers: 19
10/20/2008 12:18 AM
Thanks smiley! I've bookmarked this. I'll buy some of their softwares when I visit USA for they are not that expensive.
