Previous in Forum: electric gocart controler   Next in Forum: Volume flow rate
hdd partion not shown in my computer
10/19/2008 10:35 AM
i am not able to see the 2 partition of my hard drive e: & f: plz help me
Re: hdd partion not shown in my computer
10/19/2008 5:17 PM
Others may correct me, but I think the problem may be cmos set up?
Regards JD.
10/20/2008 8:48 AM
no dat's not the problem tell how i associate the drive to open directly by double click. in xp sp3
Engineering Fields - Electrical Engineering - New Member United States - Member - New Member
10/20/2008 12:52 PM
Right click on "My Computer", go to "Manage", then select "Disk Management" under Storage. If you have partitions that are active and readable, you should see them shown. At this point, you can assign available drive letters to those partitions. Good Luck, hope that helped.
Tom
10/22/2008 5:09 AM
i able to see the partitions but not able to open directly by double click
Re: hdd partition not shown in my computer
10/22/2008 7:53 AM
Did you try the procedure I outlined above? If you see the partitions in "Disk Management", you will not be able to open them by double-clicking on them there, you are there to assign a drive letter, once that is done, exit the Disk Manager, and open File Explorer to browse your newly-assigned drive letter. If you see the partitions here, tell us what the "File System" and "Status" fields say.
Please try to be more specific about what you are seeing, it's very hard to diagnose a computer problem in this way, but even more difficult without all the details.
Tom
10/20/2008 5:26 AM
You either need to make the partition active using fdisk or something similar, or you need to format the partition.
Perfection is achieved, not when there is nothing left to add, but when there is nothing else to take away
Register to Reply 6 comments
ankur_jai (2); jdretired (1); Shawn_V_Elect (1); tdesmit (2)
