Previous in Forum: level measurement   Next in Forum: MDEA Properties
Partial Discharge Meter - Problem
10/20/2008 2:50 AM
Hi,
We are using PD tester for our application. While measuring the component(Current transformer) we found some variation in the readings of withstanding voltage from time to time.
This will put ourselves in a confused manner.
Details of PD tester:
Make: MWB,
Procured :2007
We didn't calibrate the PD unit still..(If any calibration centre is avail in india -Pls give the details)
Need your advice to come out from the above setback. If you need any more details reg the equipment pls feel free to contact us..
[Information is knowledge]
Re: Partial Discharge Meter - Problem
10/22/2008 1:57 AM
Hi,
For your clear understanding, I herewith attach the PD tester setup image.
Look into this & pls comment your advice as quickly as possible.
