Loop back to sending computer and compare sent file to received file. It shouldn't matter that the cable is still on the roll(s).
If the software can detect, compensate, avoid, or correct an anomalous condition in the system, it is, by definition, a software problem-regardless of the root cause. In the long run, for most classes of problems, it is cheaper to fix it in the SW
