Previous in Forum: gravity value   Next in Forum: WATER RING VACUUM PUMP HOW IT WORKS?
Popular Science - Weaponology - New Member India - Member - New Member
motor speed ratio limit
10/21/2008 5:25 AM
can anybody guide/suggest for limitation / standards , to increase /decrease the speed of motor by means of V- belt-pulley transmission.
if i am using std. 4pole i.e 1440 rpm, the what will be limitations?
Re: motor speed ratio limit
10/21/2008 6:00 AM
One will be the minimum pulley radius for the chosen belt.
Another will be the maximum bearing speed.
A third will be the maximum belt speed.
How about looking at belt manufacturers' data?
Good Answers: 19
10/21/2008 9:15 AM
Good answer, the belt manufacturer should be able to provide speed and bend radius limits.
The bearing design can also be a limiting factor. Tension force on the belt may require multiple belts of a larger belt.
10/23/2008 11:34 AM
You have a 4pole, 50Hz motor at ?Hp. Say 5Hp. That speed is fixed, so I assume you are wanting to modify the output of the motor either up or down in speed using a transmission.
That motor developes about 18 Ft/lb of torque..T = (HP X 5252)/RPM T = TORQUE IN LB. FT.
Going down in speed. Say 2:1. Motor at 1440 RPM and load at 720RPM. Your driven load will have double the torque (36 ft/Lb)available
Going up, 1:2, your load will only have half the torque available
There will be a lot of strange things happening with with this type of change and shouldn't just "be done on a whim". The "Breakaway" and "Pull-up" torques will change up or down among others.
Fans and other variable torque loads are even stranger.
Do a search for "The Cowern Papers".
Ed
Register to Reply 3 comments
Fangas (1); PWSlack (1); Ried (1)
