Previous in Forum: battery state of charge study   Next in Forum: Damage to CT PT while testing a 20 MW Generator.
Voltage Drop Details
10/21/2008 9:30 AM
Dear Sir,
What is the allowabel % voltage drop for 11 KV XLPE Aluminium cables as per IEEE or BIS Standard. Kindly give the details sir.
Thank you.
Regards,
T.Kailash Kumar
Re: Voltage drop details
10/21/2008 10:08 AM
British Standard 7671. Again.
10/25/2008 4:55 PM
Is the British Standard 767 similar to the US NEC? Does it dictate a max VD?
10/21/2008 10:22 AM
Cable does not have an allowable % VD. You must determine what is the max VD you can tolerate. The NEC Std suggests 3% but not mandatory. It is a design problem.
Re: Voltage Drop Details
10/22/2008 12:24 AM
The allowable voltage drop depends upon how the electrical power distribution system has been designed and the capability of the electrical loads to function suitably at the reduced voltage at the terminals of the electrical equipment. In case of motor loads you also need to take into account the voltage drop occuring diuring the starting time. Voltage drop for sizing of cables is mostly applicable for voltages upto 1000V. As a general rule for volatge levels of 3.3kV, 5kV, 6.5kV and higher it is the fault current carrying capability that plays a major role.
The standards refered by you do not define a certain % voltage drop for a cable.
Atlas Shrugged - JGD
10/22/2008 8:19 AM
How long is a piece of string?
10/23/2008 12:21 AM
Dear sir,
It is approximately 500mts
Thank you.
Regarda,
T.Kailash Kumar
Register to Reply 6 comments
Anonymous Poster (1); Current Maarey (1); kailasamvv (1); PWSlack (1); wareagle (2)
