Previous in Forum: what chemical reacts with silver?   Next in Forum: Fusion Power, A Dream Deferred
Location: Globaly - very close to the southern most point of Canada
Good Answers: 12
Building a Steam-Driven Generator
10/21/2008 11:11 AM
Hi all,
I currently use an outdoor, wood fired boiler to heat my home during the winter. I have an ample source of firewood.
I am considering a project to build a wood fired generator. So my favorite first stop is here at CR4.
I have seen posts suggesting steam as a good efficient method for creating energy and I hoped I could get some info to start my research. So I am open to suggestions.
Thanks in advance!!!!
(note: future goal is to combine the two)
-why bother doing it wrong when it will be anyway.......
Good Answers: 15
Re: Building a Steam-Driven Generator
10/21/2008 11:33 PM
Hi gdevine,
Some people just love steam engines and the use of the same, for power applications, just - not me I guess; Unless you want a babysitting job - mearly watching the boiler during the entire time of use in power generation .
I would use my firewood to generate "woodgas" and drive an Internal Combustion Engine to push the generator head. It sure would be more hands free , and safer too , cause your going to need dry High Heated steam , not the stuff your outdoor furnace produces. If I can help further, let me know.
Best of Luck
Joe Woodall, Managing Partner
Georgia Adobe LP Rammed Earth & Renewable Energy
2395 Bowman Hwy. NW.
Dewy Rose, GA 30634 C.S.A.
http://www.georgiaadobe.com
706-213-7693
10/22/2008 6:57 AM
From a practical standpoint, i'll agree with Mr 'Georgia Adobe"s comments.
Smallish wood (or coal, for that matter) boilers are a fulltime job. That's why trains employed a 'FireMan'.
The research to investigate the merits of this, G.A.'s 'wood gas', & the possibilities of Stirling Cycle to power your alternator will be satisfying in its own right.
If you always do what you've always done, You'll always get what you've always had!
Good Answers: 12
10/22/2008 8:20 AM
24 hours, and much reading later I've already abandoned the steam idea. One very good article went through the energy requirements to weight of wood.
My next topic will be on the use of a Sterling engine as a circulation pump.
Thanks
Good Answers: 12
10/22/2008 12:05 PM
... I mean Stirling.
United States - Member - Member Engineering Fields - Power Engineering - New Member
10/22/2008 11:58 AM
I have been doing some research into using an Organic Rankine cycle for low quality heat recovery. I have read several DOE and University papers on its applications to waste heat and geothermal. You should check out one particularly interesting application by some MIT students in Lesotho, Africa. The Lesotho project and many of the geothermal project were designed to provide both Heat/Hot water and Electric power. I am spending some hobby time working out the major engineering elements for a junk yard (or Ebay) heat recovery engine using over-the-counter R-134A as the working fluid for an automotive power application. Sort of a "Hybrid" Heat Recovery combined cycle machine.
gdevine (2); Georgia Adobe (1); jconn_ETEC_05 (1); sidevalveguru (1)
