Previous in Forum: regeding load calculation   Next in Forum: metals
Armour
10/23/2008 9:46 AM
I saw that 2 different types of armour used on LV cable according to the cable types i.e,multicore had GSWA and single core had AWA.so,what is the difference between the Gaslvanised steel wire armour(GSWA) and Aluminiun wire armour(AWA)?
Engineering Fields - Power Engineering - Projects Engineer
Re: Armour
10/25/2008 5:20 AM
Grade of armouring .
steel will provide higher grade of protection.
Alu is soft and easier for installation for single wires.
A wise person will understand more from a Foolish question than what a Fool will understand from a Wise Answer
Re: Armour
10/30/2008 1:25 AM
Galvanised steel is an insulating metal and will give more strength to cable.....where as aluminium armour is conducting metal....
Re: Armour
10/30/2008 3:43 AM
Galvanised steel is an insulating metal !!?
Please be careful do you mean galvanised steel is an insulator.
we have been using the galvanised steel of armoured cables as grounding .
Re: Armour
12/28/2009 6:21 AM
1C cables should have non-magnetic armour material to avoid eddy current loss in it, so aluminum armour is used, Whereas in case of 3C cables, flux linking armour will be zero because of all 3 ph current flux sum is zero at any instance, there we can use steel armour to have good protection against mecanical damage.
India - Member - New Member
Re: Armour
10/28/2010 6:52 AM
Dear sir
My understanding.
Please correct me if wrong.
Even in 3 core cables,when the load is unbalanced,there may be armour current and hence armour losses.Hence it is advisable for three core cables also to balance the load current in all the three phases to eliminate armour losses in the armour and eddy current losses in the cable support system.
Thanks in avance
Regards
gova1467
Anonymous Poster (2); gova1467 (1); SAK (2)
