Previous in Forum: Sulfur Affinity   Next in Forum: You want to ask how we will do this?
Hydrotest
10/24/2008 5:57 AM
What is the need of using Bosset & Vesselet as hydrotest vent/drain & why not other fittings ? Pl. explain their (B & V) usage. Both are used for hydrotest vent/drain conditions as per my knowledge.
Be simple and specific for a great success in Life
Good Answers: 61
Re: Hydrotest
10/28/2008 10:00 AM
You have not given us enough information to answer your question.
- Hydrotest vent/drain on what?
- Vessel? How big?
- Piping? How big?
- Where did you see these fittings called for? The client specifications? The project specification? On detailed drawings? Where?
Do it once and do it right
Re: Hydrotest
10/31/2008 10:32 AM
what I see googling those terms are what we call weld-o-lets or theard-o-lets. These are forged fittings that allow you to put small 1/2" to 2" taps on lines that you can then use to put water into the the lines for testing. And for high points to get air out filling.
Register to Reply 2 comments
