Previous in Forum: Repair and maintenace   Next in Forum: AVR power output and enrgy efficiency/savings issue
Power factor
10/26/2008 7:50 AM
Dear sir,
can we maintain power factor at unity in an industry? If yes then why dont we maintain ? & If no, then what will be its effects on the power distribution?
Pathfinder Tags: Power Factor
Re: Power factor
10/26/2008 11:19 PM
Hi,
Technical and Economics point of view UNITY P.F. is desired but Inductive Circuit recoiling as Generator is disastrous.
You can improve PF till 0.95 0r so with Economics well justified, beyond it is expensive.
Good Answers: 80
Re: Power factor
10/27/2008 10:11 AM
Kishore is correct. Above 0.95 there is little gain in efficiency for the large expense needed. The risks of resonance also increase because if the load is reduced, you might go leading. In leading mode, you tend to resonate with the distribution line. The more leading you are, the lower the resonance frequency and the higher the risks that it will happen.
This is why any power factor correction needs some controller that will disconnect the capacitor bank when we lose the load and will let the inrush transient die before re-energising it.
Re: Power factor
10/27/2008 9:24 AM
PF of unity makes system prone to resonance.
Good Answers: 103
Re: Power factor
10/27/2008 12:26 PM
He may be sceptic but he is correct and gets a point from me.
At Unity powerfactor, the inductive load = capacitive load
ie wL = 1/wC
Now for the frequency, the circuit will resonate and can you see what will happen to the system ? the resistances most likely will not be able to damp it out and bang poof the whole thing goes off.
Register to Reply 4 comments
Kishore Kaikini (1); marcot (1); sb (1); sceptic (1)
