Previous in Forum: jointing kits   Next in Forum: VCB Panels
insulation
10/27/2008 6:05 AM
what is the insualation?
United States - Member - New Member Technical Fields - Technical Writing - New Member Popular Science - Weaponology - Organizer Hobbies - Target Shooting - New Member Engineering Fields - Nuclear Engineering - New Member
Re: insulation
10/27/2008 7:10 AM
What type of insulation are you looking for? What is the application? Please refine your question.
Good Answers: 73
Re: insulation
10/27/2008 9:10 AM
In general, it is the opposite of a conductor.
That is, it keeps you from becoming part of the circuit in an electrical system by preventing the energy from leaking into other conductors.
In a heating system, it keeps the heat from leaking out (or in).
Check a dictionary for other meanings. Context is the clue as to which definition is correct.
Engineering Fields - Power Engineering - Projects Engineer
Re: insulation
10/28/2008 10:09 AM
Time for homework,pal.
atleast put some effort in defining your qustion.
A wise person will understand more from a Foolish question than what a Fool will understand from a Wise Answer
Good Answers: 42
Re: insulation
10/28/2008 10:12 AM
Insulation is the noun form of the word "insulate". The meaning given in readers dictionary, and I quote "Separate from everything around ;cover(wire)with material which will not allow electricity to pass away ". If you have any interest in electrical engineering you would have learned it in sixth standard ( in India) Your intension of putting this tag for discussion is not understood
It is an important subject in electrical Engineering as with out insulation you cannot conduct electricity.Hence lot of research is conducted to develop good insulting material too use with various electrical products .
Thermal Insulation material is another important chapter for which lot f research is conducted to develop suitable thermal insulatig materiial. The subject is too vast to discuss here.
Good Answers: 53
Re: insulation
10/28/2008 2:48 PM
A material that is highly resistant to the flow of electrons by thermal or electric potential.
plastics, epoxy resins, ceramics are good examples of electrical insulators, and glass-wool, asbestos etc are good examples of thermal insulators.
Re: insulation
10/30/2008 1:51 AM
insulation is material which never allows passage of current through it.
for cables we use PVC or XLPE for insulation.
Register to Reply 6 comments
Anonymous Poster (1); NotUrOrdinaryJoe (1); rakesh_semwal (1); SAK (1); Steve Melito (1); V.I.Abraham (1)
