Hi,
I am looking at integrating a high frequnecy changing current (di/dt) between 30MHz and 200MHz which is the output from a current transducer. From what i can tell that at this high a frequency useng an opamp would make this difficult to achieve. Are there high frewuency opamps which could be used to integrate a signal at this frequency. Also what type of capacitor would you use. For such a high frequency bandwidth it will have to be small.
Can anyone recomend components to i could use or direct me with links of where i can find this information for this.
Thanks
