I am having trouble finding an inexpensive electronic flow switch for 3/4" water pipe. I am currently using a paddle type (McDonnell & Miller) model FS5, and am on the 3rd one. They are lasting a little more than 1 year. There is a problem with a stem part rusting off & is causing a flow restriction. Would like to activate switch at approx 1/2 gpm & not have issues with normal flow of 3/4" pipe @ 80 psi. There is no load on switch, just for input to a PLC. Can anyone recommend a different brand switch I can use? McDonnell & Miller does make a stainless steel (ss) unit, but it's costly and the FS5 is rated for water, but they refuse to put in a 10 cent ss part to eliminate the rusting issue.
Thanks!
