Previous in Forum: PLC   Next in Forum: thermocouple
Separator Filter Dryer
10/28/2008 2:51 AM
Hello I want to find Separator Filter Dryer (SFD). The dimeter of receiver output is 150 mm. I have max 5 bars air.
Thanks in advance
Re: Separator Filter Dryer
10/28/2008 1:00 PM
You may want to post this in the mechanical section as most of these systems whether the are mechanical type vortex filter separators or electrical filter types may be better supported over there... the other information is the gas and or particulate size for the moisture that it may be exposed. also what is the delivery pressure required not only the available pressure of 5 bars...
just to help in where this would be better served...
Good Answers: 19
11/10/2008 1:20 PM
I feel that you are looking around for an in-line Moisture Separator for Compressed air 150mm, 5 bar.
You will find this from: Spirax Sarco/ Adca/ Ayvaz/TLV/Gestra.Available in sizes 15mm-300mm.
Basically they are all baffle-plate type to be installed in-line with an automatic air trap at the bottom.
Register to Reply 2 comments
