Previous in Forum: ESD Best Practices and Compressed Air Use.   Next in Forum: Flange Dimensions and Types
17 comments
Heat Treatment on Drawing (8620)
10/28/2008 11:38 AM
I am having a roller or small wheel machined from 8620 and I am having difficulty figuring out how to specify the heat treatment.
It should be carburized, hardened and tempered, but all the reading I have been able to do, does not give any indication of how to specify the heat treatment in a drawing.
Do I stop at simply stating "carburization" and the required "Case Depth" and Rockwell Hardness. Or do I need to be much more specific.
Also, does bar stock usually come stress relieved and annealed or do I have to specify that as well?
This part can and will fail if it is not heat treated correctly, so I am a little stuck at this point.
Thanks in advance
Re: Heat Treatment on Drawing (8620)
10/28/2008 12:37 PM
Hi,
It's not my field of expertise, but experience says specify absolutely everything because if you don't someone will find a way of buying the wrong thing or doing the wrong process to save money (or to be 'helpful')
Ideally you should refer to recognised standards, but if all else fails you could write, 'heat to cherry red and quench in oil', (or whatever the process you require is) on the drawing.
Actually you could always add your comment...
to the drawing
Good Answers: 143
10/28/2008 12:54 PM
Turn the question around. When you receive the part(s) back from the vendor, how will you know if the correct heat treat was done? In other words, you need to spec what you can measure.
Australia - Member - New Member Hobbies - Target Shooting - New Member Popular Science - Weaponology - New Member
10/28/2008 5:00 PM
Jim,
You are already half way there.
You need to look up the steel spec sheet for your material (8620).
This will have detailed heat treating instructions for this exact material.
Attach this to your job sheet and specifiy that the materials and the Heat Treatment are as per the Job Card, design and Spec Sheet.
As an amateur Blacksmith I tend to collect them.
I think I have a copy of the spec sheet at home, if I do I will send it to you as a direct CR4 mail rather than a post. The other option is to contact your material supplier and ask them for it.
Regards,
Sapper
It's all about the Boom! - MythBusters
10/28/2008 8:19 PM
Jim,
This Link should get you to a Data Sheet for you Material.
http://metals.lincdigital.com.au/files/Product%20datasheets/Atlas8620H.pdf
You can then download and attach as required or just cut & paste the relevant bits.
Regards,
Sapper.
10/28/2008 8:33 PM
Thanks SAPPER!
Good Answers: 243
10/28/2008 11:11 PM
The spec sheet provided by Sapper is correct as far as it goes, but here is some advice you should keep in mind.
1) 8620 is low carbon and as such it will be sold in the unannealed state in the USA and Canada. (despite what the link provided by Sapper says). If you buy it as hot rolled bars, it will be in the as rolled condition.If you buy it cold drawn, it will be sufficiently cold worked to boost the yield strength probably 20% or so and increase the yield /tensile ratio and decrease ductility somewhat. I have data in my office, but I am stuck in Califrnia for a couple of days. Only if you buy it as annealled will you get annealled. (My direct personal experience making drawing and selling the stuff.)
2) The case depth is controlled by time at temperature. Diffusion of carbon in carburizing is time dependent. Given the depth, the heat treater will calculate the cycle to get the carbon into the parts. You will need to specify the case depth needed if that is going to be a rejection criteria. That info is from your design requirements, not the steel's spec sheet. So what Case depth do you need? You won't find that on the spec sheet!
3) Tempered is the name for the final thermal treatment process to relax the martensite formed in Quenching. The tempering temperature used determines the hardness /mechanical properties of the steel after the heat treatment. This too is a design decision. What hardness do you need the case to be? That will determine the tempering temperature to be used.
4) You can optimize for hardness, in the case; You can optimize for toughness in the core; You can try to get highest hardness with toughest case. These all imply different heat treat cycles.
5) Depending on the case depth and hardness, You may or may not need to carburize to get the extra carbon for the case. You have not given us size/section thickness, hardness required, nor case depth desired, so right now the advice you have is well meaning but unfocused.
What is your timeline? I will return to my office thursday, when I can provide you with additional data Specifics given your particular requirements. Is that soon enough?
On a more general note, to specify on the drawing, i would expect to find a caption such as " Rockwell C XX-XY case depth .0XX" minimum" or "Carburize and Q&T to HRC XX -XY case depth .0XX-.0YY". If toughness is really the issue, A caption such as "HRC ZZ maximum at midradius" might also be included, if you know that hardnesses greater than HRC ZZ are associated with lower toughness and more brittle failure modes.
Beware using the jominy charts without seeing the quench and dimensional equivalents . The charts provided do NOT tell you what section thickness, for example , "J4" equates to in a mild oil quench. Nor do they give you any insight into as tempered properties.
Heres hoping that you have a couple of days...
milo
Good Answers: 243
10/31/2008 1:58 PM
here is 8620 fact sheet as promised.
Since we can;'t attach pdf's i'm sending it as aphoto
Thenumbers along the left side are for case properties; thoseon the right are core. Look carefully at the units headers and you should be OK.
milo
Good Answers: 103
10/28/2008 11:37 PM
In our industry we do the following
a) The heat tretment in the drawing is mentioned in the note as "case carburize to 1.5 mm deep to 60-62 HRC"
b) In certain cases we provide the total heat treatment cycle
"Case carburize to std ...."
This can be your own std or even international standards are available. But the case depth must be specified.
c) The raw material and supply coditions are always spelt out in the drawing
"Raw material 40CrNiMo65 in HT condition" etc
Good Answers: 196
10/29/2008 4:18 AM
8620 doesn't have enough carbon in it to heat treat properly (i.e. to a controllable specification of hardness) by quenching and tempering. (Blacksmiths will argue with me on this point; but most of them don't have hardness test machines in their shops) If you want a hard surface for wear resistance then case hardening by carburizing or nitriding is how you'll get it. We usually specify the process and the thickness of the case. Don't specify hardness. You'll just get into arguments over how to measure hardness it in the thin case.
I prefer nitriding because it's a more controllable process an there are well supported proprietary nitriding processes that some high quality shops specialize in. (uh huh, read "expensive")
In all cases spend some time talking to the heat treaters so you will understand what you are getting and they can advise you properly. If this supplier contact isn't practical find a library that has a copy of the multi volume ASM Metals Handbook and spend an hour or two reading up on case hardening.
In a lot of this type of machinery applications lubrication is critical. If there is any loaded sliding contact special attention to breakin lubrication may be required.
If the wear resistance or surface failure prevention is a critical system requirement you will need some history to prove your design. Especially if you don't have access to the specialized knowledge needed to predict life of heavily loaded case hardened surfaces. In the absence of past history plan on a life testing program or carefully watch the maintenance life of the equipment. Provide a liberal warranty policy if life testing isn't possible.
With respect to 8620, like most other carbon and alloy steels, the bar stock form in which it is normally furnished is in an annealed state. If cold drawn there may be some residual stresses; but for the vast majority of applications they are inconsequential. And note that in the casehardening process the annealing is repeated. In the final steps of case hardening there is a quench that will slightly distort the part. This can require finish machining (usually grinding) if close tolerances or surface finish control is important. Again, talk to the heat treater (with a preliminary drawing in hand)
Ed Weldon
Good Answers: 243
10/29/2008 7:58 AM
Ed you give very good counsel especially about nitriding and loads.
Since 8620 has insufficient carbon to heat treat properly, why would suppliers anneal it in normal circumstances?
I will wager dollars to donuts that the normal condition of this from most cold finishers and in stock in most service centers is cold drawn unannealled. I know. I produced it that way. By the truckload. and we never annealed the hot roll for drawing, even though we could.
Central steel: http://www.centralsteel.com/alloy.htm Note not showing anneal.
Otherwise GA.
milo
10/29/2008 4:36 PM
Ed,
Blacksmiths (Modern anyway) will not argue with you.
Thats why Case Hardening was created.
The reason I keep Spec Sheets for material is so when I need to know if a material will do what I want\need it to do, I know if it will or wont and if it will, what do I have to do.
A good blacksmith will send the finished part for heat treating by a specialist in heat treating if the treatment is specific as in this case.
In the course I did on blacksmithing at Tech, we spent six (6) months on heat treating as it is so important to know where to draw the line as to DIY or outsource.
But before you can make that call you need the spec sheet to make an informed decision.
So I start from there.
Regards,
Sapper
10/29/2008 8:59 AM
Carburizing usually results in a very high carbon layer on the surface. Because this is so brittle, I usually specify a final grind to remove .001-.002" to remove it and to remove slight distortions that might arise. I've also seen carbide networks form at the grain boundries. This causes the grains to pop out and gives a surface that looks brinnelled to the naked eye. Be sure to get a temper time sufficient to remove this.
10/29/2008 6:10 PM
For what I know, the carbon content affects the heat treatability of metal ie. you have metal with small carbon content you will get a limit of hardness with heat treating. This hardness however is called core hardness. In your case, surface hardness is what you need, then carburizing or carbo nitriding will do. You need to specify the heat treating process - carburize, case depth, case hardness, and no decarburization between case and core allowed.
All these required specifications are measurable.
10/30/2008 3:25 PM
Guys,
Thanks for all the comments so far. I know a little about heat treating (Enigineering school and a very little from industry experience, so this help has been tremendous. I have a couple metals handbooks and the machinery handbook and of course the WWW. All of this does not add up to much when your making a number of different items, all needing treatment and each item having critical requirements.
The roller I am working on is a new design for an old high performance rocker arm roller from and overhead cam engine. Since I asked for help on the forum, someone has sent me a copy of an old print, and the original material was specified as SAE 51100 (which seems to something the SAE has "deadlisted" The print only called out the material, the hardness R "C" 60-64. Not the heat treat or tempering specifications.
I thought 8620 would be a good substitute due to it's ability to take (Case Hardening) carburization and the Metals Handbook indicates a R "C" of somewhere around 62 is possible.
At this point I am not sure if it's the best material. The part will be ground after heat treat and the section through the part is constant at about .21" x .45"
It would seem like the 8620H is a good choice is it is "certified" hardenable. Also it seems like I need to understand what condition the bar stock is delivered in.
The treatment times and temperature for 8620 seem to be pretty well known along with the formulas for time at certain temps due to thickness, it's just that when I look up information, differentiating between Carburizing, Hardening, Tempering and Annealing is not always done in the literature, so it can be a pretty confusing thing to self learn.
I was thinking I should specify a Case Depth of .03-.04 before grinding to have something thick enough to be able to use a Rockwell "C" test.
Any additional feedback would be greatly appreciated, the responses so far have been really great.
Thank you
10/30/2008 3:42 PM
You might look into 52100 as a replacement material.
Good Answers: 196
10/30/2008 8:41 PM
52100 is the steel used for ball and roller bearings. It is a pretty high quality material with special melting requirements in the steel mill for bearing use. You may have trouble finding bar stock in small quantities; or you may get lucky.
You don't case harden 52100. It already has 1% carbon in it's composition. I'm sure the bearing manufacturers have highly developed heat treating processes involving heating, quenching and tempering. In all my years of working with ball bearings I've never heard a whisper on the subject other than vague hardness specs in the bearing catalogs.
Roller rockers and lifters are common technology in the world of automobile racing and there are small manufacturers in the USA who make that stuff. Should be lots of info on the internet; but you may have to dig to find mention of the material used for rollers. If I drew a blank on that I'd take a look at one of the standard tool steels. They are usually readily available in bar stock though a bit pricey for most production applications.
Comments anyone closer to this corner of automotive technology?
Ed Weldon
Good Answers: 243
10/30/2008 9:20 PM
Ed you are correct about 52100, including difficulty to find in small quantities.
We produced it in Bearing Quality for automotive applications described. It will need to be spheroidized annealed, and spheroidal struture, lack of decarb, and carbide network are all issues specific to this grade as opposed to 8620.
I hesitated to suggest this 1% carbon alloy steel as a substitute for the original .20 Carbon Alloy grade, thinking that there was already a design intent for the .20 carbon grade- Ie- avoidance of through hardening and better differentiation of core/case structures/properties.
I will be providing data sheets in AM.
milo
Register to Reply 17 comments
Anonymous Poster (1); Ed Weldon (2); HarryBurt (2); jimeast (1); Milo (4); Sapper (3); sb (1); TVP45 (1); user-deleted-1105 (1); vdang (1)
