Previous in Forum: sd in coupling   Next in Forum: ash hopper
Safety Valve to be Flooded?
10/28/2008 4:19 PM
Hello
I have a pressure relief valve that gives out at 15 psig. I wanted to know if the valve needs to be flooded for it to work properly. I am noticing loss of pressure within a container i have and ive tested all other plumbing thoroughly, there is absolutely no leakage there. The tank is filled with coolant.
So the question is do i need to flood it?
Hobbies - HAM Radio - New Member United States - Member - New Member Hobbies - Hunting - New Member
Re: Safety valve to be flooded?
10/28/2008 9:30 PM
I would spray it with soap bubbles and define where the leak is for sure if the valve is on the top of the tank--Coolant(liquid?). 15 psi is nothing and unless it is 720 degrees kelvin, it should hold liquid better than air unless the coolant can digest the material that seals the valve.
Those who believe in telekinetics, raise my hand --Kurt Vonnegut Jr.
Good Answers: 123
10/28/2008 10:11 PM
The valve should not need to be submerged to work. The question I have is, is the valve leaking pressure below 15 psi?
Bob
10/29/2008 3:27 AM
"I have a pressure relief valve that gives out at 15 psig. I wanted to know if the valve needs to be flooded for it to work properly."
15psig is 15psig wet or dry.
Your application/equipment will determine what rating(s) your PRV should have;ie: PSI,temperature,BTU/hour discharge rate.
Be safe.
Register to Reply 3 comments
Anonymous Poster (1); bob c (1); Kilgore Trout (1)
