I am interested in your worst applications for bolts, and any solutions you have found.
My top two applications are:
(1) "Bolts that hold end bits on the blade of large bulldozers".
I have seen these stretch and break in all kinds conditions. One technique has been to heat the bolts and nuts, and then torque the nut on. After rapid cooling, the "heat seized" bolts and nuts seem to work better. The bolts usually took the worst beating on the side the operator seemed to favor.
(2) "Bolts that hold Jaws on a Jaw crusher frame"
Lots of stress and breakage, especially when jaw die fit surfaces are not well maintained. One solution I have seen is to make sure the Jaw dies have the proper seating surfaces.
It would be great to hear your worst applications and solutions.
Thank you
