Previous in Forum: pump hydraulic   Next in Forum: Ventury Location
8 comments
Metric gears
11/02/2008 4:57 AM
Hello, does anybody know where I can find software to draw metric gears, I have searched and could find only imperial software.
I need to save it as a dxf file so that it can be used on wire erosion or laser cutting machine.
I am using Autocad 2000.
murphyc1
Good Answers: 39
Re: Metric gears
11/02/2008 11:09 PM
How about drawing it using imperial dimensions then rescaling to the required metric size. This is what I normally do when encountering objects drawn in the wrong measuring system. I often have to switch from metric products to imperial products that are almost identical except for mounting hardware locations etc. And of course the overall size vary a bit as well. In such cases RESCALING works for me.
Admittedly if you then use DWF to publish you must manually add critical dimensions as a seperate layer. To do that I explode the dimension then edit the numbers to corespond to the size I want.
Elnav
Good Answers: 68
Re: Metric gears
11/03/2008 1:47 AM
Hello murphyc1:
These are the sites which I got searching for the term:
metric gears software drawing tool"
There is lots. You know what you want so it may be better for you to look at a few to check?
This is based on advice I gave about gears a few months ago. Though they were ready made ones.
The site I copied and pasted looks promising but I am not sure if the software is metric.
Good luck anyway. I will be looking in to see what you find.
http://www.google.co.uk/search?sourceid=navclient&ie=UTF-8&rlz=1T4GGLJ_enGB294GB294&q=metric+gears+software+drawing+tool
(The site and software below came up on the same search for 'metric' gears. Though I am not sure the software can draw metric.) It may be that Microsoft has an add-on to convert a drawing program to metric? The search term I used was
EasiDraw Gear for MS Word
EASIDRAW GEAR FOR MS WORD SNAPSHOT
EasiDraw Gear is a drawing tool that insert gears into your MS Word document. You can customize the gear by size, no. of teeth and teeth size. Enter the numbers, click Ok and the gear will be created. Windows 95/98/Me/NT/2000/XPPlatform : USD $9.99Price : 793 KBFile Size : ScreenshotScreenshot : Popularity : 7/25/2005Date Added : Click Here for SupportTechnical Support : Write Your ReviewUser Reviews : EasiDraw Gear for MS Word is a user-friendly drawing tool that insert spur gears into your MS Word document. You can customize the gears by setting: the outer radius, the inner center radius, the number of teeth and the teeth size. Enter the parameters, click Ok and the gear will be inserted into the word document. There are also 5 ready-made gears: 8, 10, 20, 24 and 40 teeth. Just simply click on the desired button and the spur gear will be inserted.
Good Answers: 68
Re: Metric gears
11/03/2008 2:10 AM
Hello murphyc1
You may also like to chech these out?
Re: Metric gears
11/03/2008 8:31 AM
I've used MITCalc. It does the strength calculations and draws the gear set. Free trial version, reqasonable for 1 yr. license.
Re: Metric gears
11/03/2008 10:07 AM
Try this online gear creator it saves as .plt file which can be converted to dxf using
hpgl2dxf.exe also a free download.
http://woodgears.ca/gear_cutting/template.html
This is suitable for laser work for wooden, acrylic gears possibly other materials
Peter Jensen
Good Answers: 119
Re: Metric gears
11/03/2008 10:34 AM
This is not an inexpensive solution but you could upgrade to Autodesk Inventor, the 3D parametric system. It has built in design accelerator functions, like gears, and also much more, like chain and gear, belt and pulley, frames(racks), etc.
Hooker
Re: Metric gears
11/03/2008 5:15 PM
Thanks for all the help. I have downloaded MITcalc and it is working fine, I will check out the other suggestions.
murphyc1
Good Answers: 68
Re: Metric gears
11/04/2008 2:16 AM
Hello murphyc1:
Glad you have found something!.
Register to Reply 8 comments
babybear (3); elnav (1); HarryBurt (1); Hooker (1); murphyc1 (1); Pj3ns3n (1)
You might be interested in: Metric Gears, Bevel and Miter Gears, Gears
