Previous in Forum: trip valve and Pressure safety valve   Next in Forum: dp level transmitter
Level Measurement
11/03/2008 9:14 AM
please kindly any body explain how to calculate the range of transmitter in open tank(level measurement) ?
and calculation of transmitter range in closed tanks? please explain this concept sir?
Re: Level Measurement
11/03/2008 10:36 PM
Can you be more specific on what type of instrument signal are you dealing with? If you are using analog signal, let's say 4-20mA then you have to use an engineering formula. This is basically a ratio of the signal change and the unit of measurement you want to get, such as volume, height, or whatever else you want. It also depends how you would be interfacing the transmitter.
11/04/2008 1:02 PM
Hi, I asked this same question somtime ago and was directed to past responses on the same issue. Scroll through the past threads and you will find alot answers to this question. But on the other hand, if your own situation is different from mine and you want specific answer. What is the height of your tank, the specific gravity of the fluid, what type of transmitter( DP or Radar ), if it's a DP transmitter, where is it mounted on the tank?
See past threads first, before we proceed.
Register to Reply 2 comments
