Previous in Forum: Level Measurement   Next in Forum: Pressure Moitoring
dp level transmitter
11/04/2008 5:13 AM
dear all,
we use a dp level transmitter to measure level in a closed tank cosist of water....the tank is always under vacuum...before a week ago I noticed that both sides of level transmitter are exposed to vacuum.
is there any way to measure the level of tank by DP transmitter under vacuum.
notes:
the pump is always runing from the bottom of tank to feed water to other areas and the tank is always supplied by water from procees.
regards,
murthe
Re: dp level transmitter
11/07/2008 6:37 AM
Well, yes, with a dptx both sides will be exposed to vacuum. There is no getting round this.
As an alternative, if the dptx is unsuitable, consider radar as a measuring technique.
Reply to Forum Thread
