Previous in Forum: Two Generators running in parallel, isolated from grid.   Next in Forum: Earthing
12 comments
creeping voltage
11/04/2008 2:17 AM
Hi. Can anyone help me for the calculation of distance a voltage can creep. Basically i have an aluminum plate on which a phoenix conector is fixed. the plate have a 8 mm pass thro hole for the connector pins. Now when 3 KV is applied between the terminal and body, there is a spark and the circiut trips. The voltage is creeping to the distance of 4 mm and trips the circuit. i want to understand that what should be the minimum diameter of the hole on plate to pass 3 KV between pin of the connector and aluminum body. if possible what will be the formula for calculation the distance.
-Bhavin. INDIA
Good Answers: 53
Re: creeping voltage
11/04/2008 11:56 AM
Here you can take an Idea.
Dielectric strength of normal dry air is about 3200Volts/mm, so 3000Volts should not jump on 4mm gap anyway.
11/04/2008 12:09 PM
Not really sure what you are trying to do, but dielectric breakdown voltage of air is about 3kV/mm. That value is however affected by multiple different factors that (might) reduce it.
http://en.wikipedia.org/wiki/Dielectric_breakdown
Good Answers: 27
11/04/2008 11:10 PM
I believe both of you are a decimal point off.
The 60 Hz dielectric strength of dry air at sea level and a temperature of 25°C is 10 kV rms per inch or 393.7 volts rms per mm (556.8 peak or crest).
The originator did not specify whether the voltage is AC or DC but, if it is DC, the corresponding breakdown voltage gradient would correspond to the AC peak or crest voltage (rms x sq rt 2).
11/05/2008 11:07 AM
When you are bringing the breakdown of air into the discussion, I believe you are talking about the strike voltage. The creep voltage is usually higher, since the spark has to "creep" along surfaces. If the surface of the structure has material on it, or is otherwise not clean, this strike voltage can be much lower.
-Bluezone
Good Answers: 15
11/05/2008 12:12 AM
I'm guessing your running a "Hi-Pot" test of your fixture?
Have you tested the fixture in the same conditions, but without the Aluminium (I guess bulk-head) in the circuit, or completely removed?
Qn, Whats the differance between a Snake and a Onion? Ans, No one cries when you chop up a Snake
11/05/2008 10:25 AM
from my old BS159 standards minimum creepage distance for 3.3kv is 50.8mm
A day without a smile is a day lost
Good Answers: 27
11/05/2008 10:42 AM
You need a hole diameter than will provide a minimum clearance of 8.5 mm from the side of the pin to the nearest edge of the hole to guarantee 3 kV rms withstand. Rounding the sharp corners of the hole in the aluminum plate would also reduce the voltage gradient and provide a more uniform field air gap.
Good Answers: 80
11/05/2008 3:10 PM
A rule of thumb that has worked in industrial application for many years is 1KV per inch of creapage distance. This takes into account some dirth and humidity but not rain... This is what we use in our electrical cabinets.
We use some Phoenix connectors. If they are the same type that we use, you should not use them at more than 250VAC. Not enough distance between metal parts.
It is very difficult to find a connector that will hold 3KV under industrial conditions. Most will need rubber boots to keep them clean and dry and even silicon grease to provide you years of reliability if you intend to cram everything within mm of spaces.
Good Answers: 80
11/06/2008 8:42 AM
There is a big difference between an air gap and a surface creapage. Dearth doesn't (usually) accumulate in a gap but it does on a surface. Also, coronas can travel on a surface from ion accumulation and static charges. This is why the V/m is much higher in a gap than on a surface.
Often adding a layer of conformal coating will break the surface creapage by providing a thin insulation layer for the conductors. Is is recognized by UL and CSA that the surface creapage distance is cut in half when a proper coating is added to printed circuit boards and similar.
Good Answers: 15
11/06/2008 10:07 PM
In my last company, we used to use "Selly's Estapol Clear Varnish" on our HV circuit boards for Electrostatic air cleaners to limit the amount of corona and flash over, worked well after 3-5 coats.
11/05/2008 9:25 PM
I wonder if you can use standard SHV BNC connectors, those are rated at 3500VAC/5000VDC typical. Diameter of the mounting hole is about 11mm or so for the panel types.
Yes, air is 3kV/mm if dry, real air though is more like 1.5kV/mm. I do a fair amount of prototyping with HV and find a good rule of thumb is absolute minimum 1kV/mm (DC) gap for bare conductors on surface of insulating substrate (e.g. PCB). In practice humidity and dirt will influence that, so 0.6kV/mm is a more conservative value (e.g. 5mm gaps for 3kV). If you design the gap according to PCB standards the figure is considerably lower - something like 0.1kV/mm.
06/10/2011 12:21 AM
Can anybody explain
What is creeping voltage?
Register to Reply 12 comments
Anonymous Poster (2); Bluestone (2); bluezone (1); Flux (1); marcot (2); peterd (1); rakesh_semwal (1); Snaketails (2)
