Previous in Forum: engineering materials   Next in Forum: Stirling Engine's for Power Generation
Tripod to support 3000lbs.
11/04/2008 12:26 PM
G'DAY,
Working with forklifts counder balance electrics.
Looking to remove a battery weight of 2700-3200lbs.from the unit.Using the head guard with a winch and out,with out tipping the unit.Can a tripod attached outside of the unit to the head guard.What measurement for this tripod?
Mech.Eng. Help
A Man who never takes a chance ,will never get a chance.!
Re: Tripod to support 3000lbs.
11/04/2008 5:51 PM
I doubt you will get a specific answer/design to your solution through this forum - there is just too much involved and there is no way a proper answer can be given with the limited information.
Good Answers: 123
11/04/2008 6:21 PM
I do not think a tripod is an appropriate thing for you to use. A tripod will do fine lifting your load as long as the movement is confined to straight vertical lifts only. You are going to have to move your battery pack out from under the tripod, unless you plan on moving the forklift out from under the hanging battery.
Be safe. Borrow, rent or steal another forklift to do this job. 3,000 pounds of battery is nothing to treat casually. There are also engine hoists that are available for rent that can lift your required load safely, and are equipped with wheels to allow movement.
Bob
Good Answers: 25
11/05/2008 2:51 AM
I have installed handling facility for battery charging rooms. Some customers who had strong truss in building had suspended monorail ('I' Beam) from the truss or had erected inverted 'U' structure and installed a Chain Pulley Block with Trolley to handle the batteries.
11/06/2008 12:04 PM
looking for a i beam attached underneath the head guard and extening outside the forklift with a tripod. Head guard height of 85"width of battery of 38"
Idea for customer with no access of other means of lifting.
Can you suggest anything?
Good Answers: 123
11/06/2008 12:39 PM
A simple tripod will allow only one lift point. Any weight hung from it will try to be directly under that point. For your plan to work SAFELY, you will need two additional legs, and take one of your three legs, and lift it till it spans the space between the two bipods. Two sets of tilted poles joined by a horizontal cross bar. The overhead crossbar will allow your battery to be slid, or rolled from forklift to above ground. It is the same idea as yours, except made wider. Good luck.
Bob
Good Answers: 25
11/07/2008 2:32 AM
I have not understood what you have suggested is it possible for you to draw a simple sketch and post it insert cam in this blog.
11/28/2008 1:11 PM
Sorry i didn't back to CR4 but a battery just crushed my hand RR
Here's a sample picture to prevent this accident any help is appreciative!
Register to Reply 7 comments
Anonymous Poster (1); bob c (2); Logic (2); suresh sharma (2)
