Good Day - Does anyone have knowledge or experience of drying wood chips? We will use them for gasification based power generation but the end use is not particularly important to this query. We want a drier design that will dry 50mmx20mmx20mm format wood chips with no fines and 40% moisture content down to 15% moisture content over a 24 hour period. We want a semi-passive process if possible, i.e. no stirring, moving belts or auger based turning. Heat is available as forced (fans)hot air at up to 80 degC - hotter is possible but not recommended. Typical site requirement is to dry 80 tonnes at 40% moisture content per 24 hours - so ending up with 60 tonnes of chips with 15% moisture content (12 tonnes) and 20 tonnes of water removed. We have looked at a variety of belt and drum driers and currently investigating high temperature steam drying. I'd like practical advice and knowledge - of design and/or suppliers of drier systems - the theory we know. In practice we will specifiy our roundwood to be air dried to the maximum before chipping so the 40% moisture content is in fact pretty much the worst case but we wish to design to that capability as part of our risk assessment exercise mitigation recommendations.
