Previous in Forum: Stainless Steel Sheets and Offshore Environments   Next in Forum: Optical Encoders and Laser Interferometers
46 comments
Battery Bank System
11/05/2008 11:15 PM
I have 8 Northstar 170 amp hr batteries connected to put out 24 volts. They are connected to a 2440 magnum inverter charger component. I use a 6500 watt diesel generator to charge the batteries. I'm at a remote site and use propane for hot water, slab heat and a cooking range. I have a propane refrigerator.My water source is a shallow well with a 1/2 hp submersible pump with a 44 gallon psi water tank.20/60 shut off psi for the start and stop of the pump. My circulating pump for the slab heat is a 24 volt march pump and is a closed system with a 30,000 btu water heater/propane with 7 lines less than 250 feet long. I use a tankless propane hot water heater. Main use of power at this time is to finish the interior of the cabin with power saws, lights and the well pump. I plan on solar panels next summer and that finally leads to my question.... I need help to design the solar system to keep the batts charged and not listen to the gen set...... Please help with suggestions or a good web sites for info... Lee from Hoyt lakes, Minnesota
Good Answers: 39
Re: battery bank system
11/06/2008 1:46 AM
Hello guest. It sure would help if you registered.
How familiar are you with doing electrical design and installation work? I do design and sometimes installation work in exactly the sort of system you have.
Many of the product websites have ample technical papers and tech notes but unless you are familiar with the specs and terminology, they may not be that useful.
Southwest Sun power and wind power has som ereally good stuff. If you can acces the Home Power Magazine website; they offer back issues on a CD. Also very good stuff. Richard Perez, the editor has been writing articles for over 10 years on the very subject you are looking for.
Backwoods is another good supplier.
Make sure you get an MPPT type controller for the solar panels. Minnisota is far enough north to give yo ua lower solar panel output compared to the "standard industry reference" whic his predicated on a south western geographical location.
I have spec'ed the North Star batteries often. Real work horses, but be sure you have your Magnum charger set for the exact voltages per factory spec.
Something that is hardly mentioned is that these North star batteries must have a certain minimum charge rate. Failure to do so will cause sulfation problems.
Solar panels quite often fail to deliver that kind of charge rate. By my calculations you need to hit these batteries with a 170 amp charge every so often t okeep them happy. 8 batteries with each pair in seriss for 24V means 4X 170 amps for a total of 680 amp hours. My guess is you are going to need that diesel genset once a month to really top up the batteries and reverse the lead sulfate build up.
Email me off list if you want more details.
Elnav
Good Answers: 97
11/07/2008 12:24 PM
Outstanding answer elnav!
11/11/2008 9:49 PM
thank you for this info. hiebtser
11/12/2008 9:24 PM
thanks, I talked to the magnum tech rep and he walked me through the set up and was very helpfull. American made to boot.....Lot of this stuff is new to me but it's interesting and I have learned alot. Thanks again for you help...
Good Answers: 39
11/12/2008 9:35 PM
Was the tech rep named Eldon Whorton by chance?
Elnav
Re: Battery Bank System
11/07/2008 11:54 AM
lee; elnav is right look at home power magazine, there at your bigger stores or theatibrary perry
11/07/2008 12:54 PM
Truely its not the size of the bank it is your average power draw that determines the wattage range for your array...Power tools do eat alot of amps but you are probably only running them intermittently ...I personally just use a genny when running any high draw stuff and use my panels for keeping the lights and a low draw computer..what you should do is add up all the rated power draws for equitment in your cabin, then figure out how long each of them runs in a day...multiply the two and that give you how many kilowatt hours your eating per day...with that I would get a sizeable enough array to give you alittle cushion. If your generator is remote startable, consider getting an auto transfer switch. It determines if the load will be a bit high for the inverter/battery bank and cuts on the generator to handle it.
My inverter, an old trace 4024, is my best friend. It has generator auto switching build in and programmable! I have it programmed to turn on the genny when load is more than 15 amps, and when the battery bank hits 50%. With that I can get away with the modest array i have, and only hear a generator but for an hour here ad there
Good Answers: 39
11/07/2008 3:22 PM
Calculating the size of a solar panel and the associated battery bank is a complex task. Because the number of solar hours per day is typically only about 1/3 of the total 24 hour period you need to replace the total 24 hour consumption during that sunny period. On the other hand the battery bank should have enough reserve to provide for an extra day if the weather is cloudy. Some experts recommend two extra days reserve. Good advice but given present cost of batteries and the fact such costs will likely escalate, this may become too expensive. But you must have at least enough capacity in the battery to run the full 24 hour period and not discharge below the safe limit.
On the other hand it may not be affordable to install a solar panel large enough to deliver the full power consumption rate needed at peak demand. Grid-tie installations are predicated on this principle. The idea being you sell back excess power during peak production periods and buy back during peak demand periods. In effect the grid serves as a storage medium. In locations where the power company pays a reasonable rate and the installation cost may have some sort of tax benefit or an actual grant, this is feasible but many locations do not have that. Nor do totally OFF-Grid installations work thqat way. New building has the advantage of being able to amortize the solar sysem cost as part of the total house mortgage, but a retrofit to an older home may not qualify for such funding. you pay the entire cost up front. Either way most solar panels cannot deliver a charge current strong enough to completely reverse sulfation. For that you need to have a periodic fast charge from a generator. Otherwise you will be replacing the batteries in a lot less than every ten years.
Generators: Those that are big enough ( typically 10kW or bigger) to be fitted with an auto start panel are normally too large for the available charger capcity. If you have a 300 - 400 amp hour battery bank then you can only use a 100 amp to 150 amp capacity charger at the most. Any more will usually cause battery damage. Depending on Battery system voltage, your charger will only demand something in the range of 2kw to 6kW at the most. The back up generator should be sized to match the charger so it runs at about 80% loading.
It makes no sense having a 10+kW generator driving a 2kW charger. not only that but it will lead to engine service problems.
Elnav
11/07/2008 8:05 PM
Having dealt with many off grid systems I absolutely love honda's 3000i(or any of their i seires). they can have an external autotransfer switch added ..it just piggys off the inverter output and wait for the load to jump to a set point .so there is no need for an industrial gen set with the auto transfer built in.
Good Answers: 97
11/07/2008 9:14 PM
You're suggesting use of two 3000i gas units instead of one 6500 diesel?
Good Answers: 39
11/07/2008 10:56 PM
Are the Honda 30001 the model that has an inverter internally and can be synchronized with a cable joining the two generators?
If not, some of the big inverters will overload the 3000 watt genset.
Gas versus diesel. Hmmm! This is a bit problematic. Long term usage with welders show that a typical gas engined welder will run about 3000 hours before needing an overhaul, The same capacity welder with a diesel runs 10,000 hours before an overhaul.
Unless you plan on running for many hours on end, and acumulating much moer than 3000 hours the greater cost of a diese genset may not be justified. Secondly if this is a back up genset which will see the most use in winter time, gasoline may prove easier to start at very cold temps.
I can personally wouch for how nasty it gets trying to start a smal d iesel at -20 below . In fact most of the newest consumer propane blow torches do not deliver enough heat to really warm up a 6kW size genset motor block. Even after ten minutes you can stil lplace your bare hands on the cylinder head. And if your batteries are already delpleted, you may not have enough power for electric glow plug heating.
My twenty year old Bernz propane torch seems to deliver twice the heat output as the new models sold in the consumer stores. At least judging by how fast it heats and how quick it uses a bottle. A cold starting diesel will also smoke more until warm than a gasoline generator.
Propane or natural gas fuelled gensets are very nice. But propane has a problem with really cold starts lower than -30 C The vaporization point of propane is around -34. colder than that and it simply won't volatize and burn. Ask any propane fuelled vehicle driver. Now you need electric fuel heaters etc.
Best bet is gasoline.
Elnav
Good Answers: 97
11/08/2008 4:18 AM
Don't let the diesel get cold, park it on a heated slab within an insulated envelope and be prepared.
Good Answers: 39
11/08/2008 12:04 PM
REPLY
Okay I'll bite. How do you propose to have a heated slab in a solar house. Heating a ground slab in winter is somewhat energy intensive. In fact the only effective method I know of is not recommended for solar houses because it does use so much energy even though the primary heat source is a wood fire.
Elnav
Good Answers: 97
11/08/2008 12:51 PM
Maybe a few bites
As stated is generally correct. However we're considering a very small footprint, just enough to house the genset and fuel and just warm enough; about 45°F, to prevent cold start issues.
The foundation would include space dug for leveling aggregate, minimum four inch Styrofoam insulation, six to eight inches of sand and topped with heating element covered by 2-1/2" to 3" concrete. The thermal mass of this configuration enables low power consumption.
The shed could be of a low head height or not more than six feet and be thoroughly insulated or about eight inch Styrofoam in wall and roof sections. A door and a removable wall section, no windows.
Good Answers: 39
11/08/2008 1:20 PM
REPLY
With all due respect bwire, that is some expensive generator installation, not to mention which, it will use a lot of electrical energy for the heating element. For a solar house this is not practical. Even if you only use a 100 Watt heater element you end up using a kilowatt every ten hours. For a solar PV installation this is very energy intensive. Since the back-up genset is not going to be run on a daily schedule, you end up using a lot of energy - just in case. After all the intent is a back-up if the solar panels do not get enough sunlight.
Far cheaper to select a fuel and engine that is easier to start under cold conditions. I agree the Honda series looks like a good bet. And if this is the model that can be synch'ed with another for more power, so much the better. The shelter you describe may be cost effective for a larger genset installation such as my uncles-in-law use on their off-grid installations but not for a small 3kW or 6kw installation.
Consider also that pure solar houses are most often built by people very conscious about their impact on the environment and the esthetics of their buildings. It is an unfortunate fact of life that in higher latitudes with freezing temps and snow fall, you will need a genset from time to time. You just don't know when or for how long. But no point in making the installation too expensive or intrusive. Your shelter would cost as much as the generator.
Elnav
Good Answers: 97
11/08/2008 1:29 PM
REPLY
I thought maybe the "element " term could derail you though was my intention to use tubing with an aqueous solution for thermal transfer.
A thermal mass in this application can continue to heat a space for several days.
Good Answers: 39
11/08/2008 2:17 PM
A wood fire heated hydronic system was what I was originally talking about being the only cost effective system. Unfortunately solar power applications engineers also advice not to use this with purely solar systems installations. The smallest cirulation pump for a hydronic systems uses 130 watts and can run as much as 300 watts if the pipe run is long enough. This is in fact the kind of systems we sell. A customer has recently asked for exactly such a system and I am specifying a dedicated small linverter to power the pump to minimize parasitic losses compared to his 3kw inverter for general use. The 3kW inverter has a sleep mode to reduce parasitic loads under no demand conditions. However with hydronic heating, especially the wood boiler type, you must keep the circulation pump going 24/7 or risk boiler damage from excessive temp swings. Which means you would end up running a 3kW inverter to support a 130 watt load. Doesn't make sense. The efficiency curve for so low a demand is way down to about 25%
I based my comments on cold starting from having driven diesel vehicles since 1984 in cold northern Ontario. Temps there are similar to the mid west. More recently I have played around with small single cylinder utility diesel engines in northern BC. Glow plug assists for cold starting draw around 800 - 900 watts. Ether or propane injection is discouraged by most mechanics due to potential engine damage.
Electric heat for cold start will draw enough power that it could kill the battery since many solar installations are set for a very low threshold on the deep cycle bateries. And lets not forget the actual cranking will also consume electric power. And if the back up genset is a start-on-demand type, it will have electric start. Otherwise you are back to using a pull start portable utility generator. If you are talking about pull starts then a gasoline genset also makes more sense than a diesel.
Elnav
Good Answers: 97
11/08/2008 3:35 PM
It is interesting how similar are marine applications to those isolated or off-grid.
For instance take into account the efficiency required on board wind powered vessels or with back-up engines which are predominantly diesel.
I direct your attention to this hydronic heater. We use these in heavy trucks to heat the cab and prevent cold starts. Diesel engines are far more efficient in this application.
Good Answers: 39
11/08/2008 4:48 PM
REPLY
Absolutely! I had my first Webasto on my boat back in 1970. I lived aboard in Toronto harbor right though the winter. These newest hydronic heaters are quite an improvement over the technology we had back then. I have also installed or serviced Espar, Proheat and Hurricane brand heaters. They are very popular in the Pacific North West where people boat year round. Unfortunately the present price of diesel makes them somewhat expensive for large scale building heat. One of my clients discontinued using his because the diesel cost four times as much as what his bill was for electrtic heat. Currently I am working with a company that sells Woodmaster wood boiler that coincidentally are fabricated in Minnisota.
Elnav
Good Answers: 97
11/08/2008 5:14 PM
I am acquainted with several folks whom have been using the Woodmaster for from 1 - 5 years. One family bought one to heat their shop then the next year got 3 more for the home and other buildings.
Now that the ethanol plants are closed cost of corn is dropping quickly and though the maintenance is high I'll suck it up. The clinker is simpler to dispose than ashes. I can burn the clinkers in the pot belly in my shop.
Good Answers: 39
11/08/2008 5:51 PM
Clinker? as in left from burning corn cobs? or from something else?
I always wondered how good the corn cobs were as a fuel.
The WoodMaster brochures show the product against a back ground of corn fields. Here in northern BC we burn mostly beetle killed pine. But now with so many wood pellet plants in operation even this wood is being put to good use. Unfortunately it now also has a value and the days of totally free wood are numbered. Mind you, the pellet mills are somewhat picky as to what they will use for premium grade wood pellets. They do not like to mix specie of trees. Spruce, Hemlock, Willow and Cottonwood, not to mention birch and various other evergreen trees are also shunned. These are left in a pile to be burned as scrap. Or as fuel for homes. <grin>
Elnav
Good Answers: 97
11/08/2008 9:14 PM
I've burned wood for heat in the past and thought the soft wood you're grinning about were labor intensive because of short burn for BTU cycles and cleaning of flue due high creosote build up.
Good Answers: 39
11/08/2008 11:39 PM
Guilty as charged. Which is why I prefer birch. Proprely seasoned it comes a close second to traditional hardwoods like maple and oak for firewood.
Elnav
Good Answers: 97
11/09/2008 12:43 AM
You have a decent supply of beech too which is similar but I recall may offer greater BTU.
Good Answers: 39
11/09/2008 2:17 PM
Not too may beech trees in my immediate locality. I have been looking.
However; I am still looking for a good way to convert wood into electricity. So far the best option is a Stirling engine. Unfortunately the only two sources of a manufactured Stirling engine in a suitable size will not sell into North America at this time. I also have plans for a tiny model of a Stirling engine but lacking a machine shop and the necessary time this is not a viable option at the moment. Plus the model would have to be scaled up to have adequate power output.
Given the poor economy at the moment, I have not found any potential investors or anyone willing to help fund an R&D project. The company I am working with has taken some older wood furnaces in trade. We could modify one of them to accept a Stirling engine into the top of the fire box.
I located a Swiss company that makes a pellet stove/Stirling generator but they told me they were not prepared to sell anything to North America until more field tests had been completed closer to their factory. Curiously enough, it was a dutch engineer who told me about it. He was over here to negotiate a contract to supply his power station in Europe with 100 tons of pellets per day. I'm told somethign like 90% of the pellet production in BC is being shipped to Europe at this time. A pellet mill was built just down the road from us and their entire production output is shipped out by rail car. No local sales.
I'm working on devising a better energy storage system. Last month I put together a proposal for a ranch and the cost of the needed battery bank amounted to $80,000 My uncle-in-law's off-grid house battery bank cost $2500 and I got him a good deal at my cost. The local battery supply store quoted him $4000 for the same battery bank. Its getting ridiculous how expensive lead acid batteries are getting. Unfortunately any other energy storage system cost even more.
Elnav
Good Answers: 97
11/09/2008 2:42 PM
In the 1980's L. Merrick Lockwood developed a 5hp Stirling engine burning rice husks.
I'm contemplating a hyperbolic reflector / Fresnel lens / glass coil filled with oil and heat exchanger and I have the same restrictions
Good Answers: 39
11/09/2008 3:30 PM
Thanks for that reference. Even a quick Google search produced many good hits.
One sentence caught my attention.
"This engine ran quietly and promised good durability but.... falling world oil prices and vanishing interest in alternative energy within the US Govt. scheme of things, scratched funding for further work". This from a recent letter from Mr. Lockwood. The incalculable harm done by the lobbying efforts of the entrenched oil industry will go down in the history books as being among the biggest man made disasters for our civilization.
With a small 1- 3 kW genset running pretty much 24/7 you can generate and store enough energy to maintain a western style household as far as the electrical energy consumption goes. And it doesn't have to be a large battery bank when the genreator runs continuously. The bank only has to be large enough to support starting surge loads of inductive motors and short term peak demand loads for maybe half an hour at a time.
Elnav
Good Answers: 97
11/09/2008 4:45 PM
Ubetcha!
11/12/2008 9:21 PM
I use a converted a semi cab sleeper that works great for my gen set bldg. It's insulated and the first cold snap I put a propane heater in the sleeper and ran it for only 30 minutes and the diesel started right away. If I had it to do over I would of put it on a slab and ran some pvc pipe from my cabin slab heat system.. It is'nt that inconvenient to heat up the small area with propane but the slab heat is very nice and efficient. Thanks
11/11/2008 9:51 PM
Please reply with more info regarding the honda gen set... Hiebster
11/07/2008 10:39 PM
I like the Home Power magazine - they have a really good section on PV panels - you can read some of the primer articles on line as well - http://www.homepower.com/home/. Good luck!
"Being unconquerable lies within yourself." - Sun Tzu
11/10/2008 11:47 AM
in responce to the 3000i question . I do not think they can be stacked like the 2000i's. In terms of overloading gens, inverter charger units i come into contact with (xantrex, trace, frontius, sma) can be programed to limit its the current draw from an ac source. I usually put that limit to 60% of the rated operating current of the genset(around its rated peak efficiency sweet spot.)
Good Answers: 39
11/10/2008 12:55 PM
I am familiar with the current limiting feature but that isn't the point. Every so often you need to hit a battery with a large enough charge current to flush out the residual lead sulfate. The charge current should be about 25% of the total Amp hour capacity. On a 800 Amp hour bank this means a charge current of 200 amps. How many solar panels installations can deliver so much current?
A Trace or Xantrex inverter charger can usually only use half as much wattage for charging as it can deliver inverting. So a 4000 watt inverter will use 2000 plus 15% or roughly 2300 watts. But that is not enough current to properly recharge a fully depleted 800 amp hour bank at a C/4 rate. In round numbers you would need a 5 kW generator to deliver the right charge.
And when you use a limited charge current the charging takes so much extra time. Worst case is when the charging takes 8 - 10 hours. Getting back to the original thread purpose. If you have a 4000 watt inverter that can only absorb at most 3000 watts while charging and the genset is a 12kW or worse a 15kW; then th egenset is only loaded lightly. Under extremely cold conditions, the engine block may never warm up properly. My suggestion was that it would be better to have a smaller genset that could be fully loaded to its optimum point. I'm more used to diesels and their sweet spot is around 80% but maybe you are right that gasoline gensets have a sweet spot at 60%. Either way both instances is way more than the 20% - 25% a Trace 4024 loads down a big Onan of 12kW - 15kW capacity.
My question about the paralleling was because I just finished a system design that used a Honda 2000 and that model does have the parallel cable feature. But I am not familiar with the 30001 series.
Elnav
11/12/2008 6:16 AM
A friend of mine is working at a system that uses solar panels to drive water pumps. He told me that he was able to find solar panels that operate as 12VDC output with a mean full power of 200W, with something like 1/2 sq. meter area. They're GE made. I'm pretty sure you're gonna find over the web several different panel specifications, as he told me that's what they have chosen among the options.
A combination of panels will give you the desired voltage and power. However, I'm affraid it's not gonna be too cheap to install, you're gonna need some pairs.
The arrangement you mentioned suggests that you have a total of 680Ah@24VDC assuming 12V batts. To find out really how much power you need in solar panels, how long do you expect your batteries to be charged by sun? If you'd like to have the same power of the generator, you'd need roughly more than 30 solar panels of such type...
Humm... suspicious you are...
11/12/2008 9:02 PM
thanks for the info. I would like to use a dc pump for water from my well. It is only 14 feet deep. I have a 18 inch culvert with the 1/2 horse 10 gallons per minute submersible pump. I always have at least 6 feet of water in the culvert. the well is 25 feet from my cabin. I have a 44 gallon psi tank that kicks in at 30#s and off at 50#s. The pump uses alot of surge power and the dc pump would be great. I use a 24 pump for my in floor closed heat system and that works great. It sounds like I will always have to have a generator to help charge the batteries even if I use solar panels. I'm very happy with the magnun 2440 inverter charger system. I have the option for a gen start module but start it manually for now. The gen set I bought is a chinnese special that looks great but I dont have the world of confidence in it. Alway listening for strange noises and pray it keeps running. All this stuff is new to me but very interesting. Helps to eliminate the trial and error stuff with good info from people like yourself. thanks again... Lee
Good Answers: 39
11/12/2008 9:20 PM
Ah ha! Now I know what you want. We provide cattle watering stations which run from a small solar panel driving a Shureflo submersible pump. These pumps can lift as high as a couple of hundred feet but do not develop much pressure since they dump into a drinking trough. BUT. . . they are great for low voltage limited current flow and driven directly from a solar panel without needing a battery. . The beauty of these is the absence of a battery which requires maintenance. A cattle watering well placed miles away out on the range doesn't get much attention.
You might need to have a seperate pressure pump fed from a storage tank. We also use the Shureflow DC presure pump. Given your very shallow well the submersible 24V pump may be able to generate enough pressure to operate your system. Even so I recommend a cistern or storage tank inside your cabin for a reserve when its dark and the solar panel pump will not run. This second pump could be either 24V direct or a small 120V AC pump. Trouble is these use more power than the direct dirve 24V DC pumps because they typically develop more pressure.
Elnav
Good Answers: 97
11/13/2008 2:43 AM
Hello elnav,
You might need to have a separate pressure pump fed from a storage tank. We also use the Shureflow DC pressure pump. Given your very shallow well the submersible 24V pump may be able to generate enough pressure to operate your system. Even so I recommend a cistern or storage tank inside your cabin for a reserve when its dark and the solar panel pump will not run. This second pump could be either 24V direct or a small 120V AC pump. Trouble is these use more power than the direct drive 24V DC pumps because they typically develop more pressure.
All true but a ram pump will do the same without electricity.
http://science.howstuffworks.com/question318.htm
http://en.wikipedia.org/wiki/Hydraulic_ram
Good Answers: 39
11/13/2008 4:21 AM
bwire: a RAM pump relies on moving water and a large quantity relative to the pumped amount. In the case being discussed we are talking about a well not a stream. If yo uhave yo pump water up from a well, yo umay as well stoer it rather thna use a large amount of it to pump ans pressurize a small quantity. Ram pumps are genrally used for irigation water or systmes with open water conduits no ta closed pressurized system as is being comtemplated here. Lee is also located in an area with below freezing temps during the winter. This also precludes using running water unless the stream is large enough to prevent freezing. My mention of a cistern or storage tank was intended for a relatively smal ltank that could fit into the building envelope so as to remain heated above freezing during winter.
Elnav
Good Answers: 97
11/13/2008 7:36 PM
elnav,
The moving water is a cause of gravity from a cistern or tank to a ram pump. The ramp pump requires no electricity.
But it is not well suited for the application
11/17/2008 10:28 AM
Would it be smart to remove my existing ac submersible pump and put a sureflow 24volt in my heated cabin. Would this pump enough water from the 14 foot well to pressurize the 44 gallon tank with a psi switch set at 30 start and 50 stop. I have a pitless adapter set in the culvert with the 1 inch line running to the cabin below the frost line. the culvert is 25 feet from the cabin. Like I said I use a 24 volt pump to circulated water glycol in my closed in floor heat system and it works great. I heard I could use a capacitor inline to my existing submersible pump to lower the startup amps when the pump starts to help lower my draw on my bank?? I thought about getting a larger tank and just pump water from the well with a dc pump of some sort and use a cheap RV dc pump to keep psi water for my cabin needs???? My inverter/charger is working great but I'm trying to fine tune the other components.... thanks
Good Answers: 39
11/17/2008 12:27 PM
It depends on how much energy you actually use. It also depends on how far fropm pump to solar PV panels. In a cattle watering station we place the PV right at the well head. But if you are thinking of running the well pump from th eexisiting PV and they are mounted some distance from the pump it is not a good idea. Do you really need to maintain pressure in your system at all times? If so why? You mention "cheap RV DC pump. Why do you consider it "cheap"?
You ask a number of valid questions but I get the impression your system has evolved rather than being plannd and designed.
The RV type pump only runs when you actually need water but an AC pump typically uses a pressure tank and if you have a pressure leak the AC pumps cycles. Using an AC pump involves a conversion loss in the inverter of around 10%. If the intention is to power the cabin entirely by solar panels then you have to start thinking about every watt you consume. your PV capacity is finite and yo uhave to make every erg count.
It is true that most RV pumps flow a lesser volume of water compared to an AC pump. However you may also have noticed that one of the energy saver methods often promoted is a flow restrictor in the shower head and faucet outlets. So s the lesser flow typical of a DC pump really an isue? The principal reason for going AC 120V in an off grid situation is to reduce losses in long wire runs. This is especially true for 12V systems and also why most newer systems are now 48Volts. But it doesn't always make sense in a system with short wire runs. Determining exactly how much energy is wasted or saved is an exercise involving a load analysis for every device used. It is time consuming but not very difficult. The formula is straight forward.
Storing 44 gallons under pressure may not be the most energy efficient, just as storing 40 gallons of hot water heated by electricity. Which is why some sytems use a storage cistern and gravity feed and either insta hot water or solar collectors for hot water. If you also used solar collectors for hot water then the more you store the better. The thermal mass of lots of hot water could help keep th ecabin warm in winter. Then bypass most of the tanks in summer when hot water capacity is not needed.
Elnav
11/17/2008 6:30 PM
Regarding the cheap rv water pumps....I meant reasonably priced and if they shit the bed you just buy another....... again could I just pump water from my well to a storage tank in the cabin with a 24 volt pump and figure out a way to start and stop the pump when the tank is full. then use the rv pump to get water to the shower, toilet and washing faucets. No I did not have the system designed by a so called professional... Common sense and hard work prevailed. Also thanks to the internet.... I realize that I won't beable to entirely power the cabin with solar panels and I will always need the gen set. I do have the water restricted in the shower and other users. My hot water comes from a tankless propane water heater and only comes on with demand. thanks for you input..
Good Answers: 39
11/17/2008 9:09 PM
Nothing wrong with designing it yourself. No one said you had to pay a professionalto do it. Yes common sense is great, provided it is applied correctly. RV pumps can provide pressure but at a flow rate somewhat slower than city water. Most of them can realistically deliver 2.5L per minute. Some pumps are rated at 3.2L and even 4.5 L per minute. But pipe diameter and lenth may reduce these figures. However what I was getting at was determining the comparative losses between using an AC pump and reducing losses in the higher voltage lines but living with the 10% extra loss in the inverter versus going direct DC 24V to a distant pump and getting maybe 15% losses as a result of line losses. The cost of using much larger wires to compensate for the longer wire run is usually not an option. However that is yet a third cost consideration.
Also, a pure DC system my in fact have lower MTBF than a more complex inverter based system.
If you already have an Insta hot (no storage ) propane water heater, so much the better. A gravity tank based system in combination with a solar collector may prove quite useful. Sine the tank would presumably be located up high and thus closer to the roof, a thermo siphon instead of a powered circulation pump might also have reduced power consumption benefits.
By design I meant doing a full load calculation for the entire system rather than simply adding on bits and pieces as the idea occurs to you. In it's simplest form a load sheet is just a list of all electrical appliances; the power consumption and the duration of use in a 24Hr period. You can get fancy and use a spread sheet so that when you play "what if" and change pieces, the final total is automatically adjusted. Now you have a real oversight as to how various options compare. I have seen some load sheets also include cost per energy unit. For an example, propane often looks like a good energy saving option. That is until you look at the $$ per BTU to heat with. It may be cheaper to use some other energy alternative.
Here in the PNW elecric grid power is so low per kilowatt that sometimes it actually is cheaper over a 10 year period to run in a $30,000 power line than to go off grid. Usually this not an option to consider in the Mid West.
Finding a way to control pump cycle as gravity tank empties and needs refilling, is easy. Several forms of float switch arrangements use form C contacts on their micro switches so you just wire it to suit. NC insead of NO. If you are into scrounging, get a water level switch from an automatic washing machine. These switchs are hydrostatically operated diaphram switches and they do have a form C micro switch. You simply adjust them to start the pump when hydrostatic pressue drops and stops the pump when pressure rises again. Same as they do in the washing machine. Its one of the things that rarely breaks down in a washing machine. A scrapped unit would often still have a working switch inside.
Elnav
Good Answers: 97
11/17/2008 9:25 PM
elnav,
Wow! You are quite knowledgeable. I thought to ask you what effect, benefit or other reaction would you think of a 120V DC system being employed in the system under discussion?
Thanks
Good Answers: 39
11/17/2008 9:56 PM
In a word I squared R losses. Secondly a single series string of 2V cells charges better than multiple parallel battery strings. A 200 amp hour 12V bank is equivalent to a 100 Amp hour 24V bank in terms of delivered power but the 24V system has one quarter as much losses with all other things being equal.
High voltage ( above 50VDC) is scary stuff compared to garden variety 12, 24, or even 48V systems.
Elnav
Good Answers: 97
11/17/2008 10:55 PM
Yeah, I remember a shipmate cutting a window in one inch plate steel with a ships power cable and a mechanical arm he fashioned together in about a half hour. It was too bright to watch with brazing goggles and sounded like MR. Thunder doing the green apple two step. The arc was about 18" and resulted in blowing three inch holes in the plate.
Reply to Forum Thread 46 comments
bhrescobar (1); bwire (15); elnav (18); hiebster (7); perry (1); rubixcubix (3); Sleddriver (1)
