Previous in Forum: Battery Bank System   Next in Forum: Finding Cracks in Polypropylene
Optical Encoders and Laser Interferometers
11/06/2008 8:52 AM
How does an optical encoder differ from a laser interferometer?
I need to make a non contact measurement of minute positional change.
What is the price range and or is it possible to lease one and for what kind of price?
Re: what IS an optical encoder?
11/06/2008 9:25 AM
How minute is your positional change ? Is it angular or linear?
Charlie don't surf.
11/06/2008 9:49 AM
Hello stevem,
I plan to measure the motion of a torsion pendulum. I expect the range to be microns or less. So it is both linear and rotational.
Thanks for replying. jim
11/06/2008 10:38 AM
Encoder background : http://en.wikipedia.org/wiki/Rotary_encoder
Since your application needs to non-contact you may want to consider using a magnetic encoder or a resolver.
http://www.admotec.com/magnetic_encoders.htm
http://en.wikipedia.org/wiki/Resolver_(electrical)
Charlie don't surf.
Good Answers: 183
11/06/2008 12:42 PM
Any encoder disk whichever design will have an inertia so that if you measure a torsion this inertia will add and may be change the natural frequency. You could use a distance measurement using a triangulation principle which is based on a reflected IR light.The surface of your rotating part has to be reflective.
11/06/2008 1:54 PM
True, in that case either a capacitive or fiberoptic probe could be used.
http://www.mtiinstruments.com/products/mti2100fotonic.aspx
Before anything can be suggested we will need to know the range, precision and response time required of the application.
Charlie don't surf.
Good Answers: 109
Re: Optical Encoders and Laser Interferometers
11/07/2008 2:19 AM
Hi,
very good and very sensitive capacitive transducers are made by
Lion-Precision (St.Paul)
Fogale-Nanotech (France)
Micro-Epsilon (Germany)
PI (Germany)
I tested these and had very good results.
Then I made my own ones - much cheaper.
Laser triangulation is not at all near the quality of capacitive sensing for small distances.
RHABE
11/07/2008 12:15 PM
Call Keyance. They have systems directly designed for this application. I have one that we measure dynamic movement of piezoelectric transducers during actuation in the 0.05 to 25 um @ up to 150 Hz.
Register to Reply 7 comments
Anonymous Poster (1); bluelakecabin123 (1); nick name (1); RHABE (1); stevem (3)
