Previous in Forum: Water Tube Boiler: Surface Condition of Outer Tube   Next in Forum: Friction on Rubber surface Area
15 comments
JIS Japanese steels
11/06/2008 3:59 PM
A Korean manufacturer says the ASTM and SAE standard steel specification means nothing to them, I must specify in JIS.
Any help in finding comparison tables?
Steel offered was SS400. Now, would that be the same as the US series of SS 400 steels? Or does JIS have SS400 steels of different chemical compositions?
Any help would be appreciated. Thanks.
Re: JIS Japanese steels
11/06/2008 4:46 PM
I believe JIS ss400 is equivalent to 1018/A36; in JIS - the "ss" stands for structural steel - "SUS" stands for stainless steel.
If I recall correctly - you can run into weldability problems with the ss400 grade due to more maganese or carbon allowed in the spec.
11/06/2008 4:59 PM
11/06/2008 7:48 PM
My thanks to both guests.
In the table I see that our SS (stainless steel) is SUS, in the JIS standards. Thanks, I was not aware of this. Perhaps SS400 is a plain carbon steel like A36 or 1018. Hmm.
Regards
11/06/2008 8:08 PM
According to the ASTM Handbook of Comparative World Steel Standards:
JIS G 3101:1995 - SS400 does not have an equivalent Steel Number nor UNS Number
Furthermore,
In the hot-rolled condition the strengths are:
Section thickness ≤ 16 mm: Yield min = 245 N/mm2 : Tensile min = 400-510 N/mm2 : Elong min = 17 %
16 ≤ t < 40 mm: Yield min = 235 N/mm2 : Tensile min = 400-510 N/mm2 : Elong min = 21 %
>40 mm : Yield min = 215 N/mm2 : Tensile min = 400-510 N/mm2 : Elong min = 23 %
Lastly (it is a mild steel) there are no specifications (min nor max) on C, Mn, Si, Cr, Ni, Mo, or 'others';
The only chemical composition specification is:
Weight % maximum
P = 0.050
S = 0.050
11/07/2008 8:44 AM
Thank you very much.
That steel is not really suitable at all to what I need. I am sure glad I asked. For a moment I thought it would be a high quality Stainless Steel.
Thanks again.
Good Answers: 243
11/07/2008 9:35 AM
in addition to the Worldwide Guide to Equivalent Irons and steels available from ASM,
http://hts.asminternational.org/content/ASM/StoreFiles/ACFAB8B.pdfYou could also look at acquiring a copy of Stahlschlussel, the key to steel. http://www.azom.com/Sale.asp?SaleID=305
And by the way, Your korean suppliers behavior on this technical issue is an important clue for you regarding how they will handle other issues in the future. Good luck.
milo
11/07/2008 10:39 AM
Thanks Milo,
I too see that as a clue to his general behaviour.
Rolf
11/07/2008 9:35 AM
What worries me is your statement "...means nothing to them...". If they are competing on the world market, and have no knowledge of any standards other than their own (particularly given that what they offered was not what you wanted) then I would run, not walk, away from that supplier. Or offer to do business with them only AFTER they educate themselves. They should be the ones to know which standards their products meet in the market they wish to contend in. You need to know the product offered meets the standard YOU are working under, not the standard they are comfortable with. But that's MY approach...results may differ
11/07/2008 10:51 AM
Everything was nicely specified in ASTM and SAE standards. It is a weld structure of three housings including water tight welds. What do I do if it leaks after I get it? I am over here in N. A. I only went there because the draftsman is from there and he says he has connections.
Now, should I take the time and trouble to find in each case the JIS number? Or should I just walk away. Perhaps the latter is the better option.
The prices were low, but I fear the workmanship will be too. And heck, you are right, if these people want to compete on the world market, they better know the "standards" of the world.
Thanks for the tip.
Good Answers: 243
11/07/2008 11:07 AM
Hey.
"I only went there because the draftsman is from there and he says he has connections."
I'd like to see that in the ISO Manual!
You are on top of this issue, obviously you brought your critical thinking to work today.
Good luck.
milo
11/07/2008 11:44 AM
Yeah, "connections" - his brother-in-law, who would be named "Guido" in Sicily, makes steel for the "Family" business... Doesn't meet any ASTM or SAE Standards I've ever heard of either!
Good Answers: 243
11/07/2008 11:48 AM
You make a good point, how come the "connections" never seem to work out in our favor, only in the favor of the "connectee" and the well meaning intermediary?
milo
11/07/2008 12:36 PM
It probably would if the intermediary told someone he "had a connection" and it was YOU. Maybe you don't have enough shady acquaintances?
11/10/2008 2:14 PM
would be nice to speak in 3 languages: ASTM, SAE, and JIS
11/07/2008 12:26 PM
Oh really,
If the manufacturer does not know ASTM or SAE specs then they are a bit player in the game. RUN AWAY, or charge the hell out of them for the "TEACHING".
This shows a real management problem with the company. Oh this is normal for bit players.
Register to Reply 15 comments
Anonymous Poster (5); EnviroMan (3); Floram (4); Milo (3)
