Previous in Forum: JIS Japanese steels   Next in Forum: mechanical gear stuff
Friction on Rubber surface Area
11/06/2008 9:10 PM
Does the surface area affects the frictional force between a rubber and other materials. The friction equation only says, F = uN; which doesn't include the surface area of contact. Is there any equations out there that includes the surface area?
Pathfinder Tags: area friction rubber
Re: Friction on Rubber surface Area
11/07/2008 3:00 AM
Theoretically surface area doesn't matter...but of course we all know that's bollocks not necessarilly true in all practical case.
I suspect with a material like rubber there are many complex variables.
I'd believe experiment over calculation in all but the simplest cases....
I'm willing to be wrong on this though.
Good Answers: 143
11/07/2008 10:26 AM
No. Surface area usually does matter in the case of rubber, but there are no first principles that apply universally - thus no equations. There are some "fudge" factors that people use to modify the simplified equation you used, but most people use graphs based on experimental data.
11/08/2008 12:00 AM
If area didn't matter, Formula 1 cars could run on bicycle tires. The tire, however, is not on a perfectly smooth surface, and is deformable. As a result, it shapes itself to the "grain" of the road and gets extra friction. The larger the contact patch, the more friction it gets.
Of course, compound and other factors are also involved, but this is a perfect illustration of why area sometimes matters.
Register to Reply 3 comments
HarryBurt (1); TVP45 (1); user-deleted-1105 (1)
