can you guys help me install my staad pro 2007 . my teacher installed it to me long time ago in my vista. i had to reformat my pc now i reinstalled it and place the cracks. wht license should i check if i prefer ACI. so i also have to check structural passport? i notice i can design stell but when i comes to concrete i cant no output. but when i use the example RC design there is. i tried to do this for two pcs. i think im doing something wrong or lacking comthing with license or with the design. buy i use to design perfectly. my cd is from magnitude staad pro 2007.
If you have an up to date copy of Staad Pro, the details you need will be on the CD somewhere.
I suggest you un-install your software of Staad Pro, including all shortcuts it may have installed, by going to SET PROGRAMS ACCESS AND DEFAULTS.
Go down the list and click on your software and remove it.
Then put the CD of Staad Pro in and run it and set it up from what comes on the screen. Follow the instructions and try again to configure it as you need.
The link below may help and there will be other links on you-tube as well. Download the links to your computer as the link I enclose below is just the first one.
If this does not work, request help in the SOFTWARE AND PROGRAMING section of this site. There will be people there who know more about it than I do, and will give you advice as they deal with software questions all the time.
The google link below has a good selection of help and forums just for Staad Pro. We cannot actually do this for you but we can help. But you might be better to visit a dedicated forum for Staad Pro.
I am the only one to have replied on this thread. Repeat the question in
Good luck and try to do the things in order and do not rush it.
Read everything on the screen to make sure you do not miss anything.
Take care...........................
I ask you most kindly to explain why you are saying the words you did? It seems to me this problem was solved a long time ago so why are you opening it up again?
The way you phrased your question is not good English which this site relies on. There is no "?" after your very few words. Why did you write in and say anything? I was thinking it may be because you and the OP (Original Post) were talking on PM but, a guest cannot talk on PM! So whats going on?
Post # 3, has not replied and asked anyone, especially a guest, rather than a member anything about his request, which you have to assume is dead and over, finished.
Look at the dates of the posts and you will see just how many months have past since this question was posted as a thread.
You cannot just pop up out of the blue and ask this question, it has to be preceded by a request, OK?
I suggest you also check out the Computer and software section of the site, to which the request may well have gotten a fuller, more certain answer.
