I am designing a very small scale, vertically-oriented space frame, which will receive uniform axial loading. The 'space frame' exterior dimensions measure 8'-0" high (2.44m) x 4'-0" wide (1.22m) x 2" thick (51mm). The chords of the space frame are 1/8" diameter (3.18mm) steel wire. The space frame is triangulated 3-dimensionally using a pyramid-shaped joint system to distribute axial loading from the top of the frame to the bottom of the frame. Question: Would one determine the axial force in any space frame chord analytically by using the same method used for wood trusses (i.e Method of Joints or Method of Sections or Graphically)? I would think analyzing the joints with Free Body Diagrams (using M.O.J. or M.O.S.) would work on a space frame as it does with a wooden truss. Any help you can provide would be greatly appreciated! Mach1gtx United States
