Previous in Forum: MUST SEE VIDEO CLIP of Archers Paradox   Next in Forum: Banned to Aid the Environment: Oil in Your Shop!
Electrostatic Precipitator
11/07/2008 4:47 AM
Is there any way migration velocity can be calculated considering the Voltage and the electrode spacing and the dust loading at inlet and out let.
GVK
Pathfinder Tags: ESP
Re: Electrostatic precipitator
11/07/2008 5:54 AM
Yes. Carry out field trials on suitable equipment.
Good Answers: 183
11/07/2008 7:20 AM
I do not understand your answer. He asked for a way to calculate and you write "yes" and at same time recommend trials but do not give any indications about how to compute the displacement in the electrostatic field.
There is somewhere a contradiction since the calculation is based on a theoretical model and the trial is done to validate the model or determine the coefficients which are specific to the application and cannot be determined by only theoretical assumptions.
Good Answers: 101
11/07/2008 10:38 AM
You can download lessons on how to design an ESP at the following website:
http://yosemite.epa.gov/oaqps/eogtrain.nsf/DisplayView/SI_412B_0-5?OpenDocument
Re: Electrostatic Precipitator
11/08/2008 4:43 AM
The questing was related to migration velocity and the purpose of asking the question is due to the fact that two independent ESP manufacturers have come up with two different migration velocity which are far apart for the same electrode spacing, voltage and infact the dust loading at inlet and out let.
What i want to know is, the ways of calculating the Migration velocity.
GVK
Good Answers: 183
11/08/2008 1:26 PM
As you can find in the docs recommended above the velocity is function of parameters which could have been differently chosen by the 2 companies. The one is the gas viscosity which function of temperature (for gases the higher the temperature the higher the viscosity) and the form coefficient of the particles in relative movement to the surrounding gas. If a mist droplet has to be considered at so low relative speeds as spherical it is not the case with other materials.
But it can be somewhere also a computation error.
Good Answers: 101
11/09/2008 2:19 AM
Within the downloadable lessons you can find the equations needed to compute the migration velocity. That is why I suggested the site to you.
Register to Reply 6 comments
DVader1000 (2); gautamkum (1); nick name (2); PWSlack (1)
