Previous in Forum: The Future of UWB   Next in Forum: 220V 50HZ to 110V 60HZ
United States - Member - US Citizen - Born & Raised Engineering Fields - Control Engineering - HVAC/R Simplified Using PLC Controls Engineering Fields - Instrumentation Engineering - HVAC/R Simplified Using PLC Controls Engineering Fields - Energy Engineering - HVAC/R Simplified Using PLC Controls
Network Access Points / (WDS) Wireless Distribution System
11/08/2008 7:39 AM
I have an on-going need to connect multiple ethernet based PLC controllers back to an HMI in a wireless configuration. I currently use the Engenius brand EOC-8610S-EXT configured as a WDS.
My difficulty is that the WDS configuration may be in conflict with other wireless network routers in the area as the unit must be addressed as 192.168.1.2 for WDS. The PLC's must have a static IP address in their ethernet setup. I cannot use DHCP routing. I use the MAC address filter for communication to/from the HMI and each AP.
My PLC's and Engenius AP are connected in each building through an unmanaged switch. I have intermittent com failures that are unpredictable.
My question is, am I using the right configuration of the AP to obtain the communication I need? Does anyone have any experience in successfully setting up an Engenius AP in WDS mode?
"Memorize the calculations, you look like a fool searching your notes while teaching class"
Engineering Fields - Instrumentation Engineering - New Member Hobbies - Fishing - New Member
Re: Network Access Points / (WDS) Wireless Distribution System
11/08/2008 9:01 AM
If your network is operable (at least most of operating time) it's believed configured properly. Some of switches are sensible to power supply noises. It could be a reason.
I would suggest you to add at your network some abundance as one more reserving routers(switches) in case if a main route falls. Is it possible?
11/08/2008 9:14 AM
Thank you for your response!
My switches are 24vdc powered from the same power supply as the relays. A possible problem, thank you. The fractional bandwidth I require did not neccessitate an additional router for redundancy. The wired portion of the network has never had a problem. When my "wireless" connections get interrupted, the "wired" connections continue without any interruption.
Any additional thoughts?
11/08/2008 9:44 AM
You've said "the same power supply as the relays"? How they are rated? Just today I had a problem with wire 485 network connected to PC. When relay was switching I forced to replug my USB-485 connector as communication error occurred.
As for "wireless connection get interrupted", I'm wondering could you program the PLCs in such a way that if so it could be re-started by a WatchDog timer then resets itself and reload program with an recovered communication configuration. It could as well to try get restarted a problem switch(s).
The com problem you described might be theoretically caused (barely) "contaminated" memory registers(stacks) in PLC due to industrial noise.
11/08/2008 12:48 PM
Yes, I'm leaning toward "industrial noise" as I have had the same installation at another site without a problem. The only difference was the revision of the Engenius EOC-8610 AP. I am visiting the site on Monday, 11/10/08, and will make a few modifications. I will keep all informed?
Register to Reply 4 comments
