Previous in Forum: Lug bolt patterns. Are they standardized?   Next in Forum: 1940 Ford 6/12 Volt Charging System
18 hp Briggs and Stratton Starter?
11/08/2008 3:32 PM
I have a Model 310000 engine. New battery, on the 4th since April this year. Interstate batteries from Home Depot. Just brought from the shop and was told the battery was DOA. A known good battery did not have any loss of charge during testing for a week. Now home with new battery and I just get a load constant sound from what appears to be the starter. I charged the battery and get same response. Is there a way to test if the starter is bad for a lawnmower? I know you can take car starters to Autozone and they will test it.
Re: 18 hp Briggs and Stratton Starter?
11/08/2008 4:51 PM
I have remedied a condition that sounds similar to what you describe by making sure all the cables are in good shape and the connections are free of corrosion or anything that can act as an INSULATOR.
Bud Trinkel
Good Answers: 97
11/09/2008 1:09 AM
Try here and find a location near you and they'll ascertain the issue
11/09/2008 3:36 PM
Check start relay, start switch and associated wiring for proper operation or errors. Also make certain charging system is working properly if you have not already done so. A slow but constant drain on the battery will kill it in a short time as standard lead-acid batteries will not tolerate even one complete discharge without damage. One possibility is the ignition switch/start switch having moisture in it causing leakage at times.
Good Answers: 97
11/09/2008 4:43 PM
Pull cable from spark plug, connect amp/meter to positive cable and monitor amp draw as you try to start, check specs for starter and battery. Disconnect or bypass ignition switch check for draw with multi-meter.
11/10/2008 11:30 AM
I'd check for a ground somewhere draining your battery to the point of ruining it. How old is it? Maybe worn brushes in starter grounding? Check all your connections, ohm to ground with the key off and see if you're reading anything. Should be quite a bit of resistance but don't know what to tell you it should read for sure. Up in the Megohms.
Good Answers: 97
11/12/2008 6:53 PM
Well let's take a rounder look...if you set a battery on the ground it will discharge. But if set on a block of wood it will hold charge.
Is this battery setting in a plastic tray, upon some shielding/insulation material or resting directly on the frame which may be resting directly on the ground?
I wonder could it be this simple?
12/24/2008 7:36 AM
bknipfer; your starter gear is not engaging the engine gear, may have broken spring on starter or rusty? perry
Register to Reply 7 comments
Anonymous Poster (1); BudT (1); bwire (3); lrsheldon (1); perry (1)
You might be interested in: Battery Holders, Battery and Fuel Cell Components
