Previous in Forum: over compensation of reactive power   Next in Forum: No Frost Fridge
Neutral - earth
11/08/2008 11:15 PM
Neutral with you earthed. When i measuring three phase voltge my multimeter. Phase voltage 480 . Same time i check with tester no indication in B phase.
Re: Neutral - earth
11/09/2008 4:47 AM
Indicate what is the connection of your transformer, I guess Secondary side is Delta B Pahse Grounded. Please Advise
Re: Neutral - earth
11/09/2008 9:49 PM
Ok, i will check . thanks you
Re: Neutral - earth
11/11/2008 7:14 AM
I understand the winding is star connected, with your certification, it is confirmed that the neutral is grounded well.
If in such confusions, some times it is best to check with lamp holder tester - with 2 220v lamps in series. & 2 wires connecting to phases ( or Volt meter )... R-Y , Y- B , B- R . You should take all three readings / checks.
If there is single phase, you shall make out immediately.
With line tester, which works on the priciple of discharge current in neon lamp, thru our body, if our hand / body is not proper earthed, some times mis leads.
harry potter.
Exploring the Science of Electricity
Register to Reply 3 comments
harry potter (1); popoy12345 (1); trajeshkannan (1)
