I am attempting to design a degree wheel that can be read in the dark without having to resort to visible light sources.
Past experience has seen remarkably bright light reflected from things like ordinary white copy paper when exposed to UV light. Even an ordinary "T" shirt glows with a brilliance that is remarkable.
I reasoned that if I sprayed a fluorescent paint on the part and then illuminated it with a Ultraviolet source that the phosphorescent paint would be excited to an even brighter glow.
It didn't happen.
Here is a photo taken in a dark room, of two disks illuminated by a low power UV light source.
The disk on the left was painted white and afterwards coated with a fluorescent paint.
The disk to the right is an identical disk, except that it is covered with disk of ordinary office paper!
Look at the difference!
I turned off the UV light source and, in the completely darkened room, the phosphor coated disk did emit a soft glow, a clear indication that it had indeed been excited by the exposure to UV.
I briefly considered simply going with the phosphor but I know that it looses energy and I can't turn on a visible light source to recharge it without compromising night vision adaption. Furthermore, the phosphor is nowhere bright enough.
In looking at those objects that have the brightest reaction to UV, it appears that what they share in common is that they are all organic in nature!
This suggest that I should simply use what works: paper. The problem with this "solution" is that the device will see outdoor use exclusively and paper can't handle that for long. Then there is the issue of turning yellow as it ages.
I've a test sample drying now that consists of the former paper covered disk which has received a thin coating of clear polyurethane paint. The hope is that the paint will seal the paper without compromising it's response to UV.
Might one of you with a knowledge of photo-reactive materials suggest a material that can respond as I'd like that can withstand the outdoors?
Thanks
L. J.
