Previous in Forum: Minimum Distance Between Pumps   Next in Forum: mechanical
mechanical
11/10/2008 4:41 AM
what is the difference between malleable iron & carbon steel
Good Answers: 230
Re: mechanical
11/10/2008 4:59 AM
Hello Guest,
Malleable Iron:
Definition: A cast iron made by prolonged annealing of white iron in which decarburization, graphitization, or both take place to eliminate some or all of the cementite. The graphite is in the form of temper carbon. If decarburization is the predominant reaction, the product will exhibit a light fracture surface; hence whiteheart malleable. Otherwise, the fracture surface will be dark; hence blackheart malleable. Only the blackheart malleable is produced in the United States. Ferritic malleable has a predominantly ferritic matrix; pearlitic malleable may contain pearlite, spheroidite, or tempered martensite, depending on heat treatment and desired hardness.
Carbon Steel:
Definition: A steel whose properties are determined primarily by the amount of carbon present. Apart from iron and carbon, manganese up to 1.5% may be present as well as residual amounts of alloying elements such as nickel, chromium, molybdenum, etc. It is when one or more alloying elements are added in sufficient amount that it is classed as an alloy steel.
Please get used to using Internet Search Engines, they will save you huge amounts of your irreplaceable lifespan, and enable you to locate useful information very quickly.
The above definitions are from: http://metals.about.com/library/
Kind Regards....
Reply to Forum Thread
