Previous in Forum: Scientific Myths   Next in Forum: Religion and science: Is the opposition inevitable ?
8 comments
Dow Corning's 3179 DILATANT COMP 22.6KG
11/10/2008 12:11 PM
Does homemade silly putty behave exactly like Dow Corning's 3179 DILATANT COMP 22.6KG?
Re: Dow Corning's 3179 DILATANT COMP 22.6KG
11/10/2008 1:02 PM
That depends on what you make your home-made silly putty out of. I am inclined to say no.
What ratio of flour to water are you using?
Safety - Hazmat - Environmental, Safety & Health Manager Hobbies - Musician - Theremin (That about says it all...)
Good Answers: 19
11/10/2008 3:26 PM
Jack of all trades,
There is neither flour nor water in "silly putty" (aka Dow 3179).
It's actually comprised of:
Dimethyl Siloxane, Boric Acid, Crystalline silica (quartz), Thixotrol ST, Polydimethylsiloxane, Decamethyl cyclopentasiloxane, Glycerine, and Titanium Dioxide
You can find an MSDS here:
http://www.hazard.com/msds/f2/bjr/bjrsz.html
Just my $0.02...
11/10/2008 3:58 PM
Thanks, Jman, you are correct on Silly Putty's chemical make up. The common ingredients in home made Silly Putty are Elmer's glue and starch. I asked the question originally because I want to test an idea that incorporates the behavior qualities of Dilatant comp 22.6kg and do not want to purchase 50lbs of it at $800, nor do I want to purchase 20 +- Silly Putty toys before I do some early simple tests. I am looking for a substitute that behaves and performs exactly like the Dilatant comp 22.6kg would.
11/11/2008 1:19 PM
You are NOT going to be able to get home-made silly putty to match the same operating parameters and act exactly like Dow Corning's 3179 dilatant compound. However, you MAY be able to get something close to match a specific application.
It really, seriously depends on the application and what you need. What is the application? We don't have home-made silly putty down here, but I cannot see it being as robust, its life as long or its results as repeatable as 3179 (especially from home-made batch manufacture).
I am thinking small scale testing is your best bet in any case.
11/11/2008 2:24 PM
JOAT, Yes, I agree small batch testing is what I'm going to have to do. Incidentally, when I say homemade, I'm referring to Elmer's glue and starch ingredients in a 2-1 mixture as demonstrated on You Tube and elsewhere: http://www.youtube.com/watch?v=Jwv29ZPmuHs Thank you. Stevec77
Popular Science - Weaponology - Cardio-7
11/11/2008 3:16 PM
Note that the listed ingredients comprise only 32 weight %.
Good Answers: 19
11/11/2008 4:05 PM
Cardio07,
The MSDS (material safety data sheet) only identifies the ingredients that are considered to be "hazardous".
According to a different source on the web, a more comprehensive (approximate) compositional breakdown of Dow Corning 3179 is as follows:
65% Dimethyl Siloxane, hydroxy-terminated polymers with boric acid
17% Silica, quartz crystalline
9% Thixotrol ST
4% Polydimethylsiloxane
1% Decmaethyl cyclopentasiloxane
1% Glycerine
1% Titanium Dioxide
(I realize that this only accounts for 98% of the composition)
Just my $0.02...
01/22/2009 11:14 PM
According to the web site below, a homemade silly putty created from Elmer's glue and Borax will be similar to the commercial stuff, differing mainly in the chemistry of the long-chain polymer.
http://www.waynesthisandthat.com/sillyputty.htm
Register to Reply 8 comments
Anonymous Poster (1); Cardio07 (1); jack of all trades (2); Stevec77 (2); The JMAN (2)
You might be interested in: Floor Coatings, Moldings, Glazing
