Previous in Forum: welding   Next in Forum: Force calculation to deflect music wire
11 comments
Aircraft Door Design
11/10/2008 7:03 PM
I would appreciate any references or research tips for aircraft door designs, especially examples of linkages, drive systems and mechanical guides. My Google searches have yielded mostly patent references and they are often not "typical" designs. Besides, they're patented.
I have a series of design projects requiring DC motor driven aircraft doors that will open/close during flight. Doors are typically under fuselage (similar to landing gear, weapons bay, etc.) - no large passenger doors. Conditions will be subsonic and nonpressurized.
Re: Aircraft door design
11/11/2008 10:57 PM
I am not expert or related to aircrafts. Thus, can give no design references
But, I would suggest you to see the Series from National Geographics on "Air Crash Investigations", many of them are on door designs
All the best
Good Answers: 22
11/12/2008 12:45 AM
Tip:- Don't copy the DC10 design. As per previous reply... see "Air Crash Investigations".. :)
Good Answers: 15
11/12/2008 7:57 AM
Remember the patent only lasts 17 years. Most aircraft accessory doors are derived from designs much older than that. Cabin doors are a little more complicated, but the doors covering unpressurized ground access points tend to be a panel with a piano hinge and a latch - frequently a Dzus or other quarter-turn fastener.
Landing gear doors are frequently attached directly to the gear itself, thus eliminating additional mechanisms of any type.
Good Answers: 119
11/12/2008 9:09 AM
I do this kind of work on a daily basis but I regret I cannot publish any of our designs. They are company/customer proprietary.
The designs we've done have been as simple as pulling/pushing a flat sheet of reinforced honeycomb back and forth to a complex curved spring loaded hurricane type shutter. They all involve DC drive motors, drive shafts, angle and "T" gear boxes, and oftentimes chains and gears. Most of this stuff is off the shelf from McMaster-Carr. The rest of the parts are fabricated in-house.
Sorry I can't be more specific and I'm well aware that there is very little to reference on the net. Fortunately, my company has a wealth of talented designers and mechanics to flesh out the designs. We also rely a lot on FAA DER's to support us when there is more design/documentation work than bodies to accomplish it.
Good luck,
Hooker
11/12/2008 12:09 PM
Sounds similar to our approches - especially the McMaster-Carr parts. We're relying on basic mechanical design know-how and lots of interface with our customer. We get the job done, but I can't help thinking that there are long proven designs with lots of flight hours.
What is the name of your firm, if you can say?
I'll check out FAA data, also suggested by another poster.
Good Answers: 19
11/12/2008 12:52 PM
That's Experimental Aviation Association, EAA, not Federal Aviation Administration' FAA.
Although, there may also be some info on the FAA or even NASA sites as well.
Good Answers: 119
11/12/2008 1:34 PM
I work for Dynamic Aviation, based out of Bridgewater, VA.
The trouble with these door designs, at least in our case, is that each mission is somewhat unique. We often reuse designs but each has to be tweaked to fit the particular equipment our customers want to fly, and the equipment is ever changing.
We are finally standardizing on other things though; hardpoints, external (protective) pods, holes in the skin with supporting structure, etc.
Virtually everything we do has to go through an FAA DER (Design Engineering Rep) for analysis and approval, so we often hire them to consult and/or design on the projects. We are looking for our own structures DER, though. These guys aren't cheap to contract or to coordinate with on their busy schedules.
Hooker
Good Answers: 19
11/12/2008 10:28 AM
Since you're subsonic and non-pressurized, maybe look around the EAA site for ideas or links.
11/12/2008 8:54 PM
Have you ever refer to the auto door design on the deluxe bus?
Some of them are also wonderful design.
01/13/2009 2:30 AM
I just wanted to notify you of a big Aircraft suppliers network called aircraftB. you can find there anything you need! especialy about aircraft designs and interiors
11/04/2009 10:21 AM
hi, My name is Harish.I m doing HND aircraft engineering..I m finding new design of aircraft door.can u send me different design of door ....I will be very thankful u.......
Register to Reply 11 comments
abasile60 (1); Anonymous Poster (2); cnpower (1); gsuhas (1); Hooker (2); OldTechNewToys (1); osborne83 (1); Ried (2)
You might be interested in: Interior Doors, Exterior Doors, Industrial Doors
