Hi,
I asked a similar question before about flat stock spring metal, but now I need to know about the force required to deflect ASTM A228 music wire. Many websites have equations for making coiled springs from music wire, but I can't find one to answer the questions below.
Assume the wire is freely supported atop two pointy triangle supports that are separated by distance L. Force F is applied downward at the centerpoint between supports. Wire diameter is D. Deflection downward of the normally straight section of wire is d.
What is the equation that relates F, L, D, and d?
For instance, what Diameter wire is required for a deflection of 0.025" with a force of .4 lbs. when supports are .55" apart?
Also, is this reasonable stress on music wire? How would this be determined? Empirically, it seems to be fine.
Thank you,
Dave
