Previous in Forum: Pull Calculation   Next in Forum: Thread Sealant
Blower Motor for Air Conditionner
10/15/2006 8:44 AM
I've a problem of using fan motors in an air condition application:
The motor is three phase, 60 Hz and rated 460 V +/- 10% but facility I've has power supply rated 380 Volts +/- 10%
Please tell me the side effects of using such power supply for short time and long run time on our air con.
Regards,
Good Answers: 120
Re: Blower Motor for Air Conditionner
10/15/2006 11:48 PM
destruction. Motor will run at 60% of rated power and may well fail to synchronize on start under load = failure is imminent.
Get a three phase autotransformer to step uo the voltage
Per Ardua Ad Astra
10/15/2006 11:59 PM
Note that your motor rating is under 60Hz. What's the frequency of your 380V 3-phase power supply? Is it 50Hz, or 60Hz?
You better off buy yourself a correct motor!
OZ
10/16/2006 12:40 AM
Hi Hazkhod,
Please check on the motor terminal connections. There might be a provision for reconnecting the motor wiring to fit your power supply of 380 V.
With your motor terminally connected to the 460-V configuration, it will deliver less torque than normal.
Regards,
Neil
Good Answers: 137
10/16/2006 6:51 AM
I suspect the 380 volt supply is at 50 Hz. If so it should work OK but power output and speed down to 5/6. Current and torque unchanged.
Assuming the fan is on a friction-only system, power absorbed is down to (5/6)3 = 0.58, so motor is not overloaded. But air flow is down to 5/6 and pressure to (5/6)2. If the fan is part of a complete aircon system needing airflow based on 460 volt, 60 Hz this is unlikely to be enough. If it's been salvaged and fitted to a different system it depends what the requirements are.
Good Answers: 804
10/16/2006 7:46 PM
Don't forget, speed will be 5/6 as well.
10/17/2006 4:37 AM
refer to electrical hand books and find your answer2
10/17/2006 4:57 AM
Hi guys,
3-phase motors with 12 wire-leads out on the terminal are generally designed to work at 220 V, 380 V and 440 V. At 440 -V supply, the motor must be wired using delta connection. At 220-V supply, it must be wired using a double-delta connection. On the other hand, if the supply is 380 V, as in this case, the motor should be wired at double-wye connection. This latter connection produces 380/sqrt(3) = 220 V on every coil of the motor, thereby, drawing the required amperage for steady-state operation.
Please check on the terminal and see the connection. The problem might be solved.
Regards,
Neil
Register to Reply 7 comments
Anonymous Poster (2); aurizon (1); Codemaster (1); JRaef (1); Neil (2)
