Previous in Forum: welding FILLER   Next in Forum: Ship Loaders and Rail Track for Jetty
welding
11/11/2008 6:34 PM
Is any formula for selecting current for welding?explain.
Re: welding
11/11/2008 7:26 PM
Please see the following guide (What Every Engineer Should Know About Welding Procedures):
http://www.modernsteel.com/Uploads/Issues/May_1997/9705_03_welding.pdf
The short answer to your question is - following the WP.
Or in the absence of one / more generally please see the following literature (or the spec sheet of the consumable you are using):
http://content.lincolnelectric.com/pdfs/products/literature/c2410.pdf
http://content.lincolnelectric.com/pdfs/products/literature/c64000.pdf
http://content.lincolnelectric.com/pdfs/products/literature/c8100.pdf
Re: welding
11/18/2008 2:14 PM
thank u
Re: welding
11/19/2008 2:46 AM
Re: welding
03/26/2014 6:07 AM
You can find Current and Voltage range of each filler wire and Electrode from manufacturer's data sheet or corresponding ASME Section-II Part-C SFA specification.
Even you can weld a test piece and measure the current and voltage.Test the specimen mechanically (Tensile,Charpy impact,bend,hardness etc. as per your requirement) after welding.If the test results meets your requirement,the recorded current and voltage is suitable for production welding.
Anonymous Poster (2); dolby (1); strider6 (1)
